Old 04-08-2005, 02:51 PM
chriskrebs chriskrebs is offline
93 Blazer, AC blows out floor vents
turned the AC on for the first time this year to normal ac. I'm getting air through both the floor vents and regular vents. The bilevel control is not selected.
Old 04-08-2005, 03:05 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 93 Blazer, AC blows out floor vents
Which setting do you have it set to.
Old 04-08-2005, 03:39 PM
it is set to normal ac, asi recall it would just blow through the dash vents not the floor vents
Old 04-08-2005, 04:06 PM
herkyhawki herkyhawki is offline
The actuators that move the dampers in the dash are operated by vacuum. Check for vacuum leaks under the hood. Also check for vacuum leak in the dash. With windows up and radio off with engine idling, you can listen for vacuum leaks in the dash.
Old 04-08-2005, 04:24 PM
Re: Re: 93 Blazer, AC blows out floor vents
yea, i looked under the hood, but didnt see any disconnected. I only saw a tee behind the distributor cap and the line going into the round cannister
Maybe i missed something, if not ill try the dash.
