Help me build my suspension.
I want to change out a lot of stuff on my factory DX suspension.
I want to know (performance wise) what I can change out without hurting my daily driveability too bad? I want a car great for straights, curves, and around town crusing. What are some pros and cons of things like; ITR lcas sway bars alignment kits strut bars urethane bushings full adjustable coilovers etc.... Any and all info will help. I've searched the web and info comes up short or confusing. |
Re: Help me build my suspension.
well there arent really any cons of strut/sway bars they will keep your turns tighter and keep the body from sawying. the new bushings will jsut help the ride be alittle cleaner. as for the adjsutable coilovers well if your jsut gonna buy coils and put them o nyor ustock struts is not bad u jsut get alittle bit bouncer of a ride. but i would probably reccommend struts and coils packages if your going lower then 1.5 inchs.
06 cbr 600 f4i 91 civic hatchback. 96 nissan pathfinder |
here's what i would go with
TEIN SS coilover suspension....................................$100 0 suspension techniques energy suspension kit...............$140 suspension techniques rear sway bar..........................$140 ebay rear lower tie bar............................................$10 ebay front lower tie bar..........................................$10 neuspeed strut tower bar.........................................$110 ebay/ skunk2 rear strut tower bar.............................$10/ $135 ingalls camber kit............................................... ..$122 total for a good suspension.................................$1542/ $1667 that's all i can think of right now...but if ur gonna do ur suspension, might as well do your brakes next
The name's Adrian 1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills 2006 G35 Coupe 6MT - Stock 2011 CR-Z - Stock Last edited by BLU CIVIC; 01-22-2005 at 09:09 PM. |
Blu civic,
This would be safe for daily driving. I really don't want a shitty ride or tires being eaten monthly. And brakes are next, I can push the brake pedal all the way to the floor with no give. I was thinking rear disc conversion of some sort and wilwood fronts. But, right now I'm focused on suspenion and driveablility. |
price is new from manufacture...can probably get this cheaper on ebay or at different web site...this is just what I would use...u can add or take away from some of the things i mentioned or go with a different manufacture
The name's Adrian 1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills 2006 G35 Coupe 6MT - Stock 2011 CR-Z - Stock |
I want a simple suspension- similar to a stock type-r in performance and driveability. But, I don't want to change out something if it causes problems in driveability now or in the future. I want pros and cons mainly on LCAs, radius rods, alignment kits, and urethane/rubber bushings.
there are no cons about the suspension setup the i showed u other than the price...and if u want something good for your car then it ain't gonna be cheap...nothing to change out, nothing to adjust (except the ride height and strut damper setting when u want to be more aggressive)
difference between urethane/rubber bushings is that urethane is better but if u don't lube it, it will squeek by alignment kit u mean camber kit? everyone has their opnions on which set-up and manufacture to go with other than that...i'm sure someone else can help u
search Tein on ebay for your car...and get polyurthane (sp?) bushings (master bushing kiy made by energy suspention $135)
_________________________________http://VelocityFactor.com________________________________ 1990 si hatch b20b si tranny megan race header 2.5 custom exhaust 50 shot integra da rear disk (w/ 4040 valve) powerslot rotors and barded lines all around 1994 Dx hatch stock |
Price is not too much of an issue. What you listed can be obtained fairly easy.
I meant progress alignment kit. Thanks for the info Blu. |
what happend to jackassi? he was the suspention dude
Nybody have Omnipower coilovers? How are they?
I think you should fix your brake pedal problem first. Safety should be your first priority. After that do your suspension.
decided to do a write-up of my dream suspension...may come true if i get this full time job dedicated to my car
TEIN SS Coil-Over Damper Kit MODEL # DSA36-KUSS1 . $1000.00 Suspension Techniques Sway Bars (f & r) $339.57 Model # http://www.optionimports.com/52155s.html Energy Suspension Kit $135.00 Model # http://cgi.ebay.com/ebaymotors/ws/eB...category=42609 Neuspeed front upper strut towers $103.59 Model #: 352070 http://www.performancepartswholesale...brand=neuspeed Neuspeed rear lower tie bar $77.68 Model # 452014 http://www.performancepartswholesale...brand=neuspeed 90-93 Integra front and rear disc brake conversion . Axis Maglite (Graphite) rims . $899.00 Model # Wheel & Tire Package 1-15x7 http://www.wheelmax.com/Wheels/Axis/axis.htm Brembo Grand Turismo Brake System/ GT Junior . Model # PT# 11.5002A .contact race technology 310-306-3158 Cusco front lower tie bar .. $85.71 Model # http://www.optionimports.com/307-475-a-.html Cusco rear upper strut tower .. $251.43 Model # http://www.optionimports.com/307-551-a-.html Orijin Motorsports Solid Control Arm Bushings .. .$95.00 Model # EFUCABN001 http://www.orijinmotorsports.com/prodefen.html Ingalls Camber Kit (x2) $244.76 Model # 35720 So far $3231.74
Well , I'm going to to order some coilovers first. Then, address my brake problem. After that I will work on completing my suspension. The car will be safe before my engine swap.
While we're on the subject of brakes I know the wilwood big brake kit would be worth it, but I hear upgrading larger rotors hurts acceleration. Is this true? Are there any aftermarket OE sized kits? Blu, I would try convert brakes to those of integras but, It is just easier for me to order from a website than search the junkyards. And I also heard an aftermarket front sway bar creates too much understeer. Is this true? Thanks |
it does create a lot of understeer...but i think itz better to have both on the street rather than just one...and to take the front off when at the track...atleast i think that's how it goes
