Go Back   Automotive Forums .com Car Chat > Mitsubishi > 3000GT/Stealth
Old 01-31-2005, 10:13 PM   #1
Old and good
Send a message via MSN to Old and good
air filters
i just installed a ebay cone air filter system and to my surprise the engien sound dramaticly changed! i now notice a drastic change in rpm ranges and other small changes.
have you guys noticed the same thing?
Old and good is offline   Reply With Quote
Old 01-31-2005, 10:33 PM   #2
turbo ES
Re: air filters
what do you mean it gets up to redline faster or what i dont have one but if it helps that much i might look into it
turbo ES is offline   Reply With Quote
Old 02-01-2005, 12:38 PM   #3
Igovert500
blue + red light magnet
Igovert500's Avatar
Re: air filters
It makes your car sound more aggressive, and if you have a TT, it makes turbo spool and the bov more audible...but as far as gains, it is only good for a few hp...nothing drastic.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Cusco front + rear strut bars
-Greddy type-s
-ATR downpipe
-no cats
-15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly.
Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical.
Igovert500 is offline   Reply With Quote
Old 02-01-2005, 04:27 PM   #4
YogsVR4
Funding the welfare state
YogsVR4's Avatar
Send a message via AIM to YogsVR4
They do help in getting the air flow going which helps the turbo models. Just the first in the line.
Never pay again for live sex! | Hot girls doing naughty stuff for free! | Chat for free!
Resistance Is Futile (If < 1ohm)
YogsVR4 is offline   Reply With Quote
Old 02-01-2005, 07:37 PM   #5
Old and good
Re: air filters
what i meant is that the engien's rpm range seems to have gotten a bit higher. but im just looking forward to going to the track and check if the 1/4 mile times have changed.
what the hp gains are concerned i think it did not give me to much but i can still feel a differance and the tourqe gains i can realy feel as i was driving on the highway the car actualy was running lower rpm nubers on the same speed as i was driving to the garage (no it was not a hill it was a straight road)
Old 02-02-2005, 01:29 AM   #6
Linebckr49
Linebckr49's Avatar
Send a message via AIM to Linebckr49
Re: Re: air filters
well ya...sorta. a cone filter, aka open element air filter, allows your engine to breath easier, especially at higher rpms. oh, and you MIGHT gain 5hp, but that's liberal. don't waste a trip to the track just to test 1/4 mile times. the only time difference you'll see is if you have a TT car, or if in your NA you launch/shift better.
yup, if ya think about it...it makes sense too. with your new filter, you allow the engine to breath easier, that is it can suck in more air w/o having to work as hard. or you can look at it as for a given rpm, it will suck in more air than it would with the stock filter. so you might see a 100 rpm difference, but most likely its quite negligible.
but the cone filter is a great supporting mod for other upgrades like FI and fuel.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Linebckr49 is offline   Reply With Quote
