| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
Port Postioning?
Does it make a difference where your port is located in an enclosure? I mean will you get the same results if your port is on the top or bottom of the front of the box, rather than be on the side? Any upsides or downsides?
Re: Port Postioning?
yes it does. you don't want port waves and sub waves out of phase. If you got a hatchback or SUV you can do subs up ports back.
2002 Ford Explorer Limited D31 yellow top Kenwood DDX-7017 2 Ascendant Audio Avalanche 18's 13 cuft NET ported box tuned to 27hz Autotek Mean Machine MX3000.1 Ascendant Audio Arco component set Orion 275SX (Mids) PPI Art Series A200 (tweets) Poly Mids for rear fill to come soon. |
SO the subs facing up, and the port facing the back of the car, or toward the rear seats?
Generally having the ports and the subs on the same plane is the best idea. In certain cars you can get better results by having them 90 degrees off, but in putting them on the same plane is the safest bet.
'01 Black Sentra SE Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8 '05 Silver WRX STi Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials |
So in your opinion, if the sub and port were on the same plane, would it matter if the port was above, below, or to the side of the sub?
no that wouldn't matter, just aesthetics
what kinda car do u have?
Ford Escort Station Wagon
subs and ports back will prolly be best.
Re: Re: Port Postioning?
Go with the subs firing up, and the port firing back on the bottom of the box. ![]() NG |
