heater core air flow
Over time, the air the the fan blows through the car has reduced to a trickle. I took the fan off and it seems to be in good shape. It is almost like the air intake is plugged.
Anyone else experience this problem and if so..... what caused the problem, and what did you do to fix it . Thanks for you help...Bryan 92 bonneville |
Your heat exchanger is plugged, if it is an r12 system and has leaked at some point oil from the freon system collects on the heat exchanger fins behind the blower fan. Dirt collects and slows the air flow. You need to remove the fan and spray some degreaser on the heat exchanger and rinse with a standard garden hose (not pressure washer). The dirt will drain out of the bottom. Your air flow should be restored. An A/C shop will charge you around 500.00 for this as they will remove heater core and replace.
Re: heater core air flow
where would i find the heat exchanger, would it be the heater core, also would there not be a filter between the blower fan the the heater core to collect the dirt
