Go Back   Automotive Forums .com Car Chat > Geo > Metro
Old 01-19-2005, 03:27 PM   #1
thetruth4130
need brakes in front
what tools will I need, 94 metro hatch 1.0 liter
i plan on getting new rotors and pads, thanks
thetruth4130 is offline   Reply With Quote
Old 01-19-2005, 04:15 PM   #2
crazyinkc
Re: need brakes in front
You will need a 12 mm wrench for the caliper but the rotor replacement requires a socket for the axle nut, a sldehammer, and a 12 mm socket and rachet. You must remove the hub since the rotor is bolted to it on the back side. You will see what I mean when you pull the wheel (I assume you know you need a lug wrench too ). If the rotors have good thickness and are not warped, I usually rough up the surface with some 40 grit to clean off the glaze and stick a set of pads on and go. You can usually rent the slide hammer from you auto parts store.
crazyinkc is offline   Reply With Quote
