Go Back   Automotive Forums .com Car Chat > Lincoln > Town Car
Old 12-07-2004, 09:55 PM   #1
danclear
89 Town Car 5.0 intermittent skip
Hey all! I have an 89 Town Car with 5.0
That will skip every once in a while. You can be driving
and all of a sudden it will start skipping. The quick temporary cure is shutting off the key for a split second and turning it back to the on position while in motion. It will stop skipping for 10 minutes or so.
This is driving me nuts!
I have replaced plugs, wires, cap, module (on the side of the distributor),coil, gas filter, I used liquid fuel injector cleaner, changed oil,
put new battery and cables! Anybody have any ideas?
I havent tried replacing the ecm yet.
Thanks! Dan
danclear is offline   Reply With Quote
Old 12-08-2004, 12:29 AM   #2
ltdltc
You mean the engine lopes, like in almost stalling?
Richard
1995 Lincoln Town Car Signature Series
Past
1992 Lincoln Town Car Cartier Designer Series
1992 Lincoln Town Car Executive Series
1990 Lincoln Town Car
ltdltc is offline   Reply With Quote
Old 12-08-2004, 09:59 PM   #3
danclear
Re: 89 Town Car 5.0 intermittent skip
Its kinda like someone unhooked about 3 spark plug wires
while the car is driving. Today I just replaced the ignition switch, I thought that worked but it started skipping again. Thanks, Dan
Old 12-10-2004, 11:29 AM   #4
ltdltc
Sounds like the infamous TFI module, http://www.coolcats.net/tech/troubleshooting/tfi.html.
It's on the base of the distributor on your car and you need a special socket to get it off.
Richard
Past
Old 12-10-2004, 10:09 PM   #5
danclear
Hi Rich, thanks, but I already replaced it.
Might try the ecm. Thanks, Dan
Old 09-04-2005, 06:35 AM   #6
DJDYNAMIKE
Cool Re: 89 Town Car 5.0 intermittent skip
Thanks! Dan
SOUNDS LIKE TO ME U NEED TO LOOK AT YOUR FUEL PRESHURE REGULATOR VALVE OR U MIGHT HAVE SOME FAULTY INJECTERS
DJDYNAMIKE is offline   Reply With Quote
