Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon
Old 11-20-2004, 10:52 AM   #1
Carfreak18
Carfreak18's Avatar
Send a message via AIM to Carfreak18
SOHC VS. DOHC Neon
Hey a friend of mine has a SOHC 2.2 Liter and his friend has the exact same car except its a DOHC....what edge will the DOHC give his friend? Say in a drag race(legally)
Carfreak18 is offline   Reply With Quote
Old 11-22-2004, 10:44 AM   #2
DanF
Send a message via AIM to DanF Send a message via MSN to DanF
There are no 2.2 liter cars unless you live in the UK or Japan, second off if thier both autos the SOHC will win because the DOHC can't make benifit of its RPM Range because its shifts too soon, if both manuals the SOHC will pull off the line then the DOHC will have him by teh end of first gear because it can rev higher and has more horse power. The DOHC should have about a tenth or two if thier both manuals maybe four tenths if its a manual DOHC vs and auto, Auto for auto the SOHC should have a tenth or so, SOHC MTX vs. DOHC ATX the SOHC should have 3 tenths or so
DanF is offline   Reply With Quote
Old 01-13-2005, 01:12 PM   #3
Master692005
Re: SOHC VS. DOHC Neon
Hey a friend of mine was doing some research on Neons and found that you can get more reliable power from a turbo charged SOHC than a DOHC. He said that alot of people with turbo DOHC blow motors. So if you plan to use turbo then you might want to take that into consideration as well.
Master692005 is offline   Reply With Quote
