EFI fuse, i need a map asap!
i need to know what fuse is the efi fuse and or can someone give me a map of the fuses under the hood. my map is gone
i need this asap and will highly appreciate it. i need to cut off the fuel so i can run a compression test.
Re: EFI fuse, i need a map asap!
bump
Does http://www.stealth316.com Have it? I'm too lazy to look right now :P
Dunno if you already tryed looking there/
RIP Andy "Hypsi87" Filson... We'll miss ya mate Quote:
Resistance Is Futile (If < 1ohm) |
need to cut off the fuel? go to stealth316.com, follow the instructions for changing/upgrading the fuel filter. in that procedure, you cut the fuel flow by unplugging the electrical connection on the fuel pump, then you try to start the car in order to relieve the fuel pressure in the lines.
bonne chance!
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
i need the one for the outside fuses
im at work right now young, but can look later for you at home. im pretty sure ive got that info there.
will be home just after 6pm uk time.
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!! 9b turbos with manual boost valve mod set @14psi turbo xs type h-rfl blow off valve blitz dome filter sachs clutch completely de-catted fuel pump voltage rewire mod ebc redstuff front brake pads greddy fully automatic turbo timer now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
thanks
dude sorry not been in touch but cant find that info anywhere but thought you can pull the fuel pump relay which is behind under the fuse box and it wont pump then anyway.
hope it helps bb
