Go Back   Automotive Forums Car Chat > Toyota > Previa
Old 06-30-2017, 12:36 AM
StillinSaigon StillinSaigon is offline
Arrow 1991 Previa Differential Noise
Differential Noise
Has anyone taken apart a 1991 Previa LE's Rear End before because I was told it was welded and had to be replaced. I've looked at it and the pinion seal needs to be replaced as well as the RR Axle Bearing. It seems the driveshaft has to be removed and then the ring and pinion gear should come out of the housing after the axles are pulled. Is this correct?
StillinSaigon®
