Old 12-05-2004, 01:55 PM   #1
rrgarmy
please help, noise from serpentine belt
Hello,
my car is a 96 cavalier coupe 2.2 4-cyl (89000 miles). Before the car warms up, there is a noise coming from the serpentine belt. It becomes more noticable (gets louder) when the car is accelerating. However once the car warms up or I spray it with some WD-40 while it's still cold the noise goes away. I have not taken the car for repairs yet, but someone recommended to me to buy and apply "belt dressing". Is this a good idea? I'm a novice and don't wish to replace the belt myself, but was wondering if anyone has any recommendations for me how to prevent the noise or what it might cost to have it repaired. There aren't any other problems with the vehicle at this time.
Thank you,
- rrgarmy
rrgarmy is offline   Reply With Quote
Old 12-05-2004, 02:30 PM   #2
jayson716
Re: please help, noise from serpentine belt
I am having the same problem with my 2000 Z24. i was told by a few people it was the tensioner. but i have yet to want to go ahead and replace that.
-Jay Jones
Team DROPZONE
Vice President
jayson716 is offline   Reply With Quote
Old 12-05-2004, 02:51 PM   #3
motown313
i had the same problem on a acclaim and i tried wd-40 and belt dressing and all that did was help for a day or two and made a nasty mess so i just changed the belt.
That worked for a little bit finally i got a smaller belt i dont think it's your tensenor. dose your tensenor self tenson? ps look to see if your belt is "shiny" or cracked?
motown313 is offline   Reply With Quote
Old 12-05-2004, 04:02 PM   #4
rrgarmy
Re: Re: please help, noise from serpentine belt
The belt looks shiny, I did not notice any cracks. I do not know if it has a self-tensioner.
Here are links to some photos I took of the belt (not removed)
http://webpages.charter.net/rr_g/belt1.jpg (with flash)
http://webpages.charter.net/rr_g/belt2.jpg (no flash)
http://webpages.charter.net/rr_g/belt3.jpg (no flash)
Old 12-05-2004, 09:01 PM   #5
motown313
ok, look on the tensioner and if it has 2 bolts, you have to loosen those bolts and pull down the tensioner and make it as tight as you can. Hold it there as you retighten the bolts. If it dont stretch the belt because it as far as will go you will need to get a new belt. take the belt to your auto parts store. It could be the wrong size. If there is no bolts there should be a square hole you can put a breaker bar in (the longer the bar the easier it will be to detension) pull down until the belt is loose enough to pull off the pully same way to replace. Hope that helps. ps if you know anything about a eagel talon im haveing starting problems (i have a post) pps. belts are verry easy to change about a 10 min job.
Old 12-05-2004, 11:20 PM   #6
public
public's Avatar
The tensioner on this car is not adjustable. They can be helped for a little while with some spray lube sprayed behind the seal. The replacement at most autoparts stores runs about $40 Good Luck.
Yes, I am retarded.
public is offline   Reply With Quote
Old 12-06-2004, 12:28 AM   #7
Classicrocjunkie
Lifted GMT-360!
Classicrocjunkie's Avatar
Send a message via AIM to Classicrocjunkie
and this is why i tell people to freakin search.....
http://www.automotiveforums.com/vbul...d.php?t=309192
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Classicrocjunkie is offline   Reply With Quote
Old 12-06-2004, 08:04 AM   #8
rrgarmy
I had actually searched and reviewed the post you linked before starting this thread and the informtion I got out of it is:
"How do I know when i need a new belt?...
Here are some signs...
~Noticeable deep v cracks
~High pictched squeeling that only gets louder when more time passes
However the belt has no cracks and the noise from mine is more of a rattle then a squeal. Even though your post is detailed, I still could not be sure if i needed an entirely new belt or to just get the tensioner fixed as it's been suggested. But I still gained insight from these replies as well as the diagram and write-up.
Old 12-06-2004, 11:29 AM   #9
Classicrocjunkie
Lifted GMT-360!
Does it sound like somthing is pinging or like tinging around?... If so i know exactly what that is.
Old 12-06-2004, 06:44 PM   #10
rrgarmy
the sound it's making is a very low pitched, repetitive "whee-whee-whee" which is noisier when the car accelerates. The noise is not a constant tone or squeal, however when the car is warmed up or i spray WD40 around the parts the noise ceases.
Old 12-06-2004, 10:53 PM   #11
Classicrocjunkie
Lifted GMT-360!
Sounds to me, you need a new Idler pully...
right below the upper engine mount.. there is a 2" pully about 4-6" down from the mount..( refer to the post i made about the replacment for exact placement).... pretty sure thats your problem...
