Old 12-15-2004, 12:44 AM
Tesla Tesla is offline
abs light on, traction control not working
I installed a remote starter in my 97 saturn sl2, and if i go over 35 mph, the abs light comes on, and i cannot engage traction control. does anybody have any solution?
thanks
Old 12-15-2004, 02:37 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: abs light on, traction control not working
traction control is a part of the ABS system, you lose ABS, you lose TC.
can you give us more info on the remote starter and the wiring you did with it?
you may need to go to a saturn dealership to have the code read.
Old 12-15-2004, 09:59 AM
the remote starter had wires that tapped into the following wires:
constant 12v
ignition
accessory
crank
dome light
parking lights
brake switch
for the brake switch, there were two wires that gave me a positive signal when i applied the brake, so i just chose one. should i try the other? or will i have to create a relay circuit to tap off of the brake wire?
