Old 12-01-2004, 10:26 PM   #1
rollin_on13s
rollin_on13s's Avatar
Question 3.2 timing belt???
anyone know off hand what the reccommended intervals are on replacement of the 3.2 timing belt??
I've got a '97 with 92K that doesn't exactly sound as tight as I would expect it to. I bought it with around 84,000mi on it, and remember wondering if I had possibly been deceived on the actual mileage...but maybe that's just characteristic noise?- or something on the outside of the motor making a low, burbling rattle sound. Definitely worth checking in to.
rollin_on13s is offline   Reply With Quote
Old 12-01-2004, 10:32 PM   #2
anthonyn
Re: 3.2 timing belt???
The burbling rattling sound is probably the notorious lifter tick that these vehicles are known for. Do a search and you'll find plenty of remedies that will quiet them down for awhile. If you haven't replaced the timing belt, @92k miles you're due. My 95.5 Rodeo has a 60k mile timing belt change interval (which I think is too short an interval).
anthonyn is offline   Reply With Quote
Old 12-02-2004, 02:14 PM   #3
rodeo02
I'd personally wait until either your water pump starts to leak, your hydraulic timing belt tensioner gives up the ghost, or you get to WELL above 100K miles before you do a T-belt replacement. Again, all 3.2's are non-interference engines, so worst case, the belt breaks, the engine stalls and you are stranded w/out a truck until it gets fixed (like tons of other things that can happen to a vehicle).
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
rodeo02 is offline   Reply With Quote
Old 12-02-2004, 04:29 PM   #4
Canucklehead
Send a message via MSN to Canucklehead
I waited until the tensioner started to go bad before I changed the belt (tensioner & water pump as well) which was at 119K miles. There didn't look to be anything wrong with the old belt when they removed it.
2000 VW New Beetle TDI
2007 Honda CR-V
Canucklehead is offline   Reply With Quote
Old 12-03-2004, 03:03 PM   #5
ibew595
ibew595's Avatar
Send a message via AIM to ibew595
I would rather replace these parts somewhere I could trust/find a deal than "have" to replace and be stuck.
What if you are on a road trip? Story in the news today, lady killed after her Escalade stopped on the freeway center median. She got out and tried to run across the freeway.
email"A.F."in subject line only
Mt. Hamilton 9/03
Kevin Goto
2000 740 i
Impala Brown
Annalisa
ibew595 is offline   Reply With Quote
Old 12-03-2004, 03:10 PM   #6
Canucklehead
Re: Re: 3.2 timing belt???
And the latest Darwin award goes to...
2007 Honda CR-V
Old 12-12-2004, 06:55 AM   #7
Letsrodeo
Letsrodeo's Avatar
My 99 Reodo operators manual recommends the T blet replaced at the 100K mile mark.
My
If you want something done right do it yourself two or three times!
1999 Isuzu Rodeo LS 4X4
American Eagle Series 149, 16X8
Toyo Open Country LT265/75R16
Rancho 9000
3" CP Lift, 3" PA Body Lift
Manual Locking Hubs, SuperWinch
Optima Yellow Top Battery
Custom Sound System
Shrockworks Rocksliders
Letsrodeo
Letsrodeo is offline   Reply With Quote
