Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 08-22-2004, 11:31 AM
EP's 2000 Durango EP's 2000 Durango is offline
Question 2000 Durange Idle surge at startup and stops
I have a 2000 Durango with about 125K on it. It's been great!! Recently it developed a problem. Went starting the engine revs right up to 2-2.5k. Then 'hunts' and finally settles down to a normal idle after about 15-20 seconds.(Really not good!!) This surging also rears it's igly head at stops too. Pull up to a stop light, the engine idles normal and then surges and hunts from 1-1.5k. Put it in neutral, and it can go up to 2-2.5k again, and after a few cycles, finally drops back to 500-700. I've been reading the forums, and have a few ideas, like the IAC, TPS, Idle speed motor, dirty throttle body, even the intake gastket... But, before I go hammering methodically through this list, has anyone else had this issue? Oh Yeah...did the spark plug thing...no difference!
Old 08-22-2004, 10:15 PM
vis_inc vis_inc is offline
Re: 2000 Durange Idle surge at startup and stops
I had the same problem TPS took care of it.
Old 08-22-2004, 10:54 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Yeah that's what I would try first as well.
My Mopars
Old 09-03-2004, 08:26 AM
Thumbs up
Cleaned the IAC, throttle body, air plenum, etc. Replaced the intake gaskets and the TPS. Runs like new!! But I have to tell you....the intake gaskets cost more than gold!!
Old 02-11-2005, 04:26 PM
_MJ_ _MJ_ is offline
not very car savy what does tps stand for?
Old 02-11-2005, 09:58 PM
lds540ans1 lds540ans1 is offline
THROTTLE POSITION SENSOR
