Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-28-2004, 07:42 PM
spanky9929 spanky9929 is offline
Send a message via AIM to spanky9929
Question 1.8L to a 2.0L engine swap
i got a 93 eclipse with a 1.8L and a 91 talon with a 2.0L and want to do an engine swap from a 1.8 to a 2.0 and was wondering how to go about the electrical system i know the engine will fit but do i have to change the wiring harness for the engine to work or can i use the 1.8 wiring harness on it the 2.0
Old 10-28-2004, 09:00 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: 1.8L to a 2.0L engine swap
you need to change the wiring harness and the ecu. the 1.8 has a different set of sensors then the 2.0
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-12-2004, 11:00 PM
matth matth is offline
I just did the same thing. You will have to do ecu, wiring harness motormounts and fuel pump sensor which is under the dash by your ECU...
Old 11-13-2004, 04:46 PM
hey matth how long did it take you to do the swap? were there any problems or custom fab needed or was it just swapping the stuff from one car to the other. i have a 1.8 and a 2.0 so i have all the parts i need.
-1stGenRocks-
Old 11-19-2004, 02:26 AM
Re: Re: 1.8L to a 2.0L engine swap
We are still working on it right now. It only took about a day to take out 1.8 and put in 2.0 . But my problem now is I am getting no spark . I have put in new coil packs and still nothing it will crank but will not start and run. I am geting fuel to my injectors. been missing with this problem for about two weeks now and getting very frustrated and I am starting to sell everything....ANY IDEAS......
Old 11-19-2004, 02:29 AM
Re: Re: Re: 1.8L to a 2.0L engine swap
1stgenrocks, by the why auto wirng harness will not work must be a manual 2.0 wirng harness...
Old 11-27-2004, 07:49 PM
Topochicho Topochicho is offline
Send a message via Yahoo to Topochicho
Re: Re: Re: Re: 1.8L to a 2.0L engine swap
Did you get this swap working?
