Go Back   Automotive Forums .com Car Chat > Ford > Taurus | Taurus Wagon
Old 11-20-2004, 01:48 PM   #1
vikdan
Heater blend door actuator power problem
I have a 99 Taurus with very little heat. Blend door actuator was not working so I bought a new one from Ford dealer. That doesn't work either. Is there a fuse for this actuator motor? The manuals I have don't show it fused. To get by, I wired the blend door shaft open but there is still very little heat. Lines in and out of the heater core are hot. It lines are restricted by corrosion will they both be hot? Help before I freeze to death.
vikdan is offline   Reply With Quote
Old 11-26-2004, 02:40 PM   #2
msisk27
heater trouble with taurus
Did you find out what the problem was? I have the same issues and two different dealerships have not been able to help
msisk27 is offline   Reply With Quote
Old 11-28-2004, 02:24 AM   #3
vikdan
Re: heater trouble with taurus
The actuator door is fused. It is called "BK LPS/ AC" and is a 15amp fuse in passenger compartment, Position #6. A friend also said that both lines can be hot with very little heat. He mentioned a by-pass/ relief line between the inlet and outlet of the heater core. I am going to backflush the heater core while I plug the bypass line. I hope it works.
Old 11-28-2004, 11:18 AM   #4
fordfool
my heat is pretty good now, since i (believe it or not) put a new radiator cap on! its still not perfect, but good. where is this bypass / relief valve? i aint seen noting like that on my 98. unless its the crossver from the waterpump to the thermostat, but thats not a valve.
fordfool is offline   Reply With Quote
