Go Back   Automotive Forums Car Chat > Chevrolet > S-10
Old 12-11-2004, 09:21 PM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
Question uneven tire wear
91 s10 blazer 2wd. my tires are barely a year old and my rear
two are both showing wires on the inside. what causes a
tire to wear like that? rotated them about 6 months ago
and didnt notice it. fronts are fine just the rear tires.
like to fix problem before i get new tires.
Old 12-11-2004, 11:27 PM
OverBoardProject OverBoardProject is offline
Banned
Re: uneven tire wear
You'll need 2 new tires anyways, so why not get that probably much needed alinement and they'll tell you.
back tires normally only wear out like that if you don't have them properly inflated, or drive like an ass, or have something bent.
Old 12-12-2004, 12:47 AM
jackass#1's Avatar
ok but would a front end alinement (which is fine)
do for my rear tires? done alinement last time i buoght tires, little over a year ago. my wife does not drive like an ass, so that cant be it, huh.
tread on the rest of tire are good just on the insides of both.
Old 12-12-2004, 01:55 AM
Banned
Ohh, so your wife doesn't live up to your name!!! That's good, and I'm sure you don't either
get a 4 wheel alinement, and you'll know for sure.
I don't think that anyone does just the front end any more.
I personally like to get an alinement twice a year on my daily driver... when I switch from summers to winters, and back. Plus whenever I get new tires
with S-10's and anything with a solid rear axle it's very uncommon for the tire wear that you, mentioned unless the person drives fast around corners... and then they should expect that wear.
I imagine that you keep a close enough eye on her tire pressure, although low pressure will usually wear the tire out on both sides
So I'd almost expect something to have somehow been bent. Possibly some really worn out bushings might be the cause too.
good luck with it
Old 12-12-2004, 09:19 AM
jackass#1's Avatar
hey thanks
