Go Back   Automotive Forums .com Car Chat > Mercury > Grand Marquis
Old 11-10-2004, 03:48 PM   #1
owo2
Send a message via Yahoo to owo2
Drive idle speed
I have a 91 GM, 302, that idles too slow after warm up and while in drive. Is there a manual speed adjustment for this or is this also controlled totally by the computer?
owo2 is offline   Reply With Quote
Old 11-11-2004, 02:27 AM   #2
fredjacksonsan
Caution: Monkeys bite!
fredjacksonsan's Avatar
Send a message via AIM to fredjacksonsan
Re: Drive idle speed
On the 5.0/302, there is an adjustment screw. It's located on the front side of the throttle bore, just below the plastic air intake running from the air box. You can reach it from the front with a regular screwdriver.
If turning it up doesn't solve your problem, it might also be your idle air valve/motor, and there are several posts on that.
Easy fix either way.
fredjacksonsan is offline   Reply With Quote
Old 11-20-2004, 10:16 PM   #3
owo2
Thank you very much...........exactly as you described..........solved the problem by turning screw.
Old 11-22-2004, 10:25 AM   #4
fredjacksonsan
Welcome. If the problem comes back and gets worse in a couple weeks, then it's the idle air valve.
