Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 11-16-2004, 06:42 PM
Tstown Tstown is offline
96 GMC Jimmy P0108
Need help. Recently received a code of p0108 - Map sensor high input voltage. The vehicle does not shift into passing gear when throttle is mashed and receiving major spark knock.
So far we have:
- checked timing set at -1 degrees
- installed new map sensor
- Recently have had the transmission rebuilt, shift problemn may not be related.
Any ideas where to check next? What would give the map sensor a high voltage input error.
Old 11-18-2004, 10:11 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 96 GMC Jimmy P0108
So far we have:
Did the check engine light come back on?
Old 11-20-2004, 04:15 AM
Yes, the check engine light comes back. Same code. Any ideas at all?
Old 11-20-2004, 12:59 PM
BlazerLT's Avatar
AF -Advisor
With MAP sensor replaced, I would have to think you might have a Computer problem.
The shifting thing is not related, but why haven't you taken it back to the guys that rebuilt it?
Old 11-20-2004, 04:29 PM
Thanks for the reply. He believes there may be a short in the computer that is affecting the shifting problem also. He is checking on a kit made by GM to fix the tranny problem. We were not sure whether the map sensor code problem could affect the electronics for the tranny. Ever heard of the a kit for that? Maybe a new computer? Any ideas on costs associated with getting a new computer?
Again thanks for any input.
Old 11-20-2004, 04:32 PM
Forgot to mention, that tranny guy believes that the downshift problem probably burned up the tranny. He could not find anything inside that would have. Just thought I would mention.
Old 11-20-2004, 04:40 PM
BlazerLT's Avatar
AF -Advisor
Watch it, it sounds like they are going to blame it all on the MAP sensor.
Transmission will not be affected by a MAP error like that.
