Go Back   Automotive Forums .com Car Chat > Mitsubishi > 3000GT/Stealth
Old 11-09-2004, 10:14 AM   #1
uncutnick3kgt
Send a message via AIM to uncutnick3kgt
MAF question
hey i was wondering if anyone is using a gm mafs and a maft setup.....
uncutnick3kgt is offline   Reply With Quote
Old 11-09-2004, 10:33 AM   #2
uncutnick3kgt
alright dumb question!!! found out a little late sorry.. but now i am wondering what people have for guages..... a/f ration, exhaust temp... some input would be cool
Old 11-09-2004, 02:53 PM   #3
Hotshot8792
what are you planning on doing, and i'll tell you what gauges you will need.
i'm guessing you have a turbo car. I have not seen any reason yet to use any gauges in an N/A car unless you are spraying.
Boost gauge is good for all turbo cars, cause the factory one just is not accurate.
A/F gauge, i would recommend not even wasting your money on one of these unless you have purchased a wideband. They do you no good on a narrow band car. You cannot use it to tune on high throttle because narrowband just tells you that you are running extremely rich as its translated onto the A/F gauge, and if you have a fuel controller and you try to lean it out using an A/F gauge without a wideband, not a good idea . If you are using a fuel controller and are tuning low throttle for upgraded injectors, just use this simple formula to tune ((dont forget to hit the percent key on your calculator) 100% - (ECU injector size/upgraded injector size)).
As far as EGT gauges go, get one if your converting an N/A to a TT or if you are upgraded fuel or turbos on a TT car.
Those about cover the 3 main gauges that are useful to the car, now, if you want to switch out the middle 3 gauges with replacement aftermarket ones, those look cool too.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Hotshot8792 is offline   Reply With Quote
Old 11-09-2004, 10:15 PM   #4
uncutnick3kgt
i am getting an ls6 maf upgrade and i have to tune out the a/f using a maft....but i wont know whether i am running rich or lean.....from what i understand u can just tune your mixture not read it with the maft... that is why i got into the guage question
Old 11-10-2004, 01:13 AM   #5
talskinyguy
Send a message via AIM to talskinyguy
Re: MAF question
If you are still on the stock fuel system just 0 out the MAFt and it will work just like the stock one but will flow a lot better. You dont have to do any correction on stock injectors.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
talskinyguy is offline   Reply With Quote
Old 11-10-2004, 01:18 AM   #6
Thourun
Thourun's Avatar
Send a message via AIM to Thourun
Re: MAF question
How much is MAFT and where can one get one, didn't see them on any of my usuall sites.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Thourun is offline   Reply With Quote
Old 11-10-2004, 01:41 AM   #7
talskinyguy
Re: MAF question
i think horsepowerfreaks has them, and they are around 200.
Old 11-10-2004, 02:09 AM   #8
Thourun
Thourun's Avatar
Re: MAF question
Damn, they sell 3SX strut bars for less than 3SX!
Getting the Z06 MAF seems realy expensive, is it realy worth the 300 something you gotta spend to get it working?
1995 3000GT VR-4
Old 11-10-2004, 10:08 AM   #9
uncutnick3kgt
first yes it is worth it because everywhere that i have read it will take almost .5 of ur quarter mile... and every little bit helps... second you can buy the whole kit off of http://www.driven-performance.com/display/206..... or if u just want to buy it all seperatly u can go to http://www.fullthrottlespeed.com/Dyn...-EVEREST-WR151
Old 11-10-2004, 10:15 AM   #10
Igovert500
blue + red light magnet
Igovert500's Avatar
Re: MAF question
You don't need to spend 300 to get it working, just pay the price, but I do remember it being over 200, I'll go check...
If anyone is interested, I found the whole kit on ikonone's sponsor's website
the ls6 MAF, MAFT, and 9inch K&N filter for $390.
I couldn't find it for $200, but I didn't look very long. The advantage is the MAF is in the low 90smm, while our stock is like 83mm or something, so it's larger, allows more airflow, and then the Translator allows you to tune for you injectors and a few other variables.
I'm going to be upgrading to it as well sometime next year.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Cusco front + rear strut bars
-Greddy type-s
-ATR downpipe
-no cats
-15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly.
Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical.
Igovert500 is offline   Reply With Quote
Old 11-10-2004, 10:17 AM   #11
Igovert500
Igovert500's Avatar
Re: MAF question
ah, you beat me too it.
And Thourun, as far as the 3sx strut bar, if you are considering getting one, get a cusco off ebay for 50-75, you wont notice a difference other than color.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-10-2004, 10:33 AM   #12
uncutnick3kgt
what about something like a data logger or such to read out the a/f since the guages are useless... cause i understand all u have to do is zero it out if u have stock but i am upgrading injectors and other things over winter.... and i cant find a data logger for a 95 only 91 and 92
Old 11-10-2004, 03:12 PM   #13
Thourun
Thourun's Avatar
Re: MAF question
Wait so you can tune your fuel delivery with just the MAFT? I'm shure you need some sort of way to find how rich your rining right? And I assume you need bigger injectors to get the .5 off you ET.
1995 3000GT VR-4
Old 11-11-2004, 07:56 AM   #14
uncutnick3kgt
from what i have read... so i'm not sure... with just the ls6 maf and the maft u can take .5 of ur quarter....i'm going to also do injectors this winter so idk but i do know that u can ajust all of it from the maft...
Old 11-11-2004, 10:24 AM   #15
mike93vr4
mike93vr4's Avatar
Re: MAF question
but is that for turbo only?
mike93vr4 is offline   Reply With Quote
