Old 11-05-2004, 03:10 PM   #1
LILT23
Angry Rpm's Goes Up And Down Please Help!!!
can someone please tell me how to stop my car from the RPM'S racing between 1,000 & 3,000 it like goes down to 1 and races back to 3 and goes back and forth the whole time out of gear it's a 5 spd 2.2 stock motor with turn down cold air intake please reply and tell me how to stop it from doing that cause it is a pain and it's burning all my gas.
LILT23 is offline   Reply With Quote
Old 11-05-2004, 06:18 PM   #2
Igovert500
blue + red light magnet
Igovert500's Avatar
Re: Rpm's Goes Up And Down Please Help!!!
Are you getting any check engine lights?
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Cusco front + rear strut bars
-Greddy type-s
-ATR downpipe
-no cats
-15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly.
Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical.
Igovert500 is offline   Reply With Quote
Old 11-06-2004, 01:32 AM   #3
ajdragonf
ajdragonf's Avatar
Send a message via AIM to ajdragonf Send a message via Yahoo to ajdragonf
There's a small air tube/valve that runs to your stock air intake that needs to be plugged in order for the engine to get the proper air mixture. Make sure you check that tube that goes to the throttle body. I had this problem when I put in my first intake. Hope it helps. To test and make sure this is the problem, put your car in idle and plug the hose with your finger, it should drop the RPM's considerably. Release the finger and it will jump up again. It normally runs at around 700 RPM's when normal. Cool?
ajdragonf kicks it
Here's a pic of my car: [img][/img]
ajdragonf is offline   Reply With Quote
Old 11-07-2004, 12:12 PM   #4
thepig333
Send a message via AIM to thepig333
I have that same problem. I have been told that there is a vaccume leak somewhere. Use a can of ether and spray the vaccume hoses and where they connect. When the car drops in rpms, you have found your leak. Replace hose. Hope that works
thepig333 is offline   Reply With Quote
Old 11-07-2004, 10:01 PM   #5
LILT23
Question code 4 is showing
i ran the cars computer for codes it is coming up code 4 and code 4 is crank angle sencor where can i find that thing at? anyone got a clue?
Old 11-10-2004, 12:45 AM   #6
cooneyb81
cooneyb81's Avatar
Send a message via AIM to cooneyb81 Send a message via MSN to cooneyb81 Send a message via Yahoo to cooneyb81
the crank angle sensor is inside the distributor, you would more than likly have to get it from the dealer.
cooneyb81 is offline   Reply With Quote
