Old 11-05-2004, 08:06 PM
BlueCivic83's Avatar
BlueCivic83 BlueCivic83 is offline
Send a message via AIM to BlueCivic83 Send a message via Yahoo to BlueCivic83
bad fuel consumption the danm thing drains the fuel tank too fast
OK what could cause bad fuel milage ? on my 89 4.0l limited ?
Could it be bad or worn sparx plugs ?
If i change to a cone air filter won it burn more fuel ?
what can i do ?
Old 11-05-2004, 08:28 PM
Dale Aeppli Dale Aeppli is offline
Re: bad fuel consumption the danm thing drains the fuel tank too fast
what can i do ?
TRY A GOOD TUNEUP, PLUGS, WIRES, CAP, AND ROTOR. CHECK AIR FILTER IF DIRTY CHANGE. ALSO CLEANING THE THROTTLEBODY COMPLETELY WILL HELP. CONE AIR WILL HELP TUNEUP WILL HELP MORE THAN ANYTHING. CHECK THE CVC LINES. DALE
Old 11-05-2004, 11:02 PM
The_Penguin The_Penguin is offline
The easiest and most obvious, air filter.
Also, dumb but woth checking, tire pressure, and e-brake dragging.
After that, the usual tune-up stuff. though *usually* but not always, if your ignition system has issues, it would be running rough, and lack power.
Old 11-06-2004, 11:57 AM
Saudade's Avatar
Saudade Saudade is offline
What mileage are you getting? Does the engine run smoothly (at speed and at idle)?
As the others have suggested, a good "tune up" to start. Then check vacuum lines.
I had a recent increase in mileage after installing an aftermarket keyless remote. Of course, the remote had nothing to do with it, but I suspect that when I disconnected and reconnected the ECU when I pulled the lower dash out, it improved a connection somewhere. So, also check the connections to the sensors. Disconnect, check for corrosion and reconnect.
