Old 10-24-2004, 09:53 AM   #1
rysin91crx
knocking at 3000?
ok, i just baught a 5spd 94 eclipse 1.8 and i noticed it will knock around 3grand. Could any one help me here? I hope its not a valve prob. Thanx for your time.
rysin91crx is offline   Reply With Quote
Old 10-24-2004, 03:41 PM   #2
1stGenRocks
1stGenRocks's Avatar
Send a message via AIM to 1stGenRocks
Re: knocking at 3000?
did you check the oil? what kind of a knock is it does it speed up with the engne?
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
1stGenRocks is offline   Reply With Quote
Old 10-24-2004, 06:43 PM   #3
Talon69
Talon69's Avatar
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
does it sound like a high pitch knock(tap) or a heavy knock?
Talon69 is offline   Reply With Quote
Old 10-24-2004, 07:17 PM   #4
GTracer1618
i hate to say this but if it is a heavy knock it might b the rod knock.. just had that in my 3000gt and had to get a used engine put in, hope its not that but does sound like wat happened to me, good luck tho man
GTracer1618 is offline   Reply With Quote
Old 10-24-2004, 11:12 PM   #5
rysin91crx
well it is a pretty solid knock, that would suck if it is the rod though. the oil that is currentley in there now is 10w-30 i was thinking about using 10w-40 just to see.. but i'm not sure. Man i hope its not the rod...
Old 10-25-2004, 04:41 PM   #6
WankelTII
the book calls for 20w50! that could definately be the problem, you arent ever suppose to use an oil with a hot viscosity rating lower than the stock specs call for. In other words 20 should be the first number, no less! And no more than 50 for the second number. A single weight oil would be fine but it should be between 20 and 50 like a 30w or a 40w. Change the oil, put some castrol 20w50 high mileage in there and get a nice oil filter, let the car idle for about 15mins and take it for a nice easy drivew and see how it sounds.
WankelTII is offline   Reply With Quote
Old 10-29-2004, 07:12 PM   #7
rysin91crx
now i see.. I just got the Haynes book out and i see what you are talking about. thanx bro. that just might work.. i will keep yall updated.
Old 10-30-2004, 05:31 PM   #8
Partizan
Partizan's Avatar
Oh my god. People, please just read the manual if you don't know something. People neglect the engine like that and then wonder what happened when they need a new engine. 5 Minutes can save you 5 grand.
Partizan is offline   Reply With Quote
Old 11-01-2004, 12:15 AM   #9
EclipsNgirl
Send a message via AIM to EclipsNgirl Send a message via Yahoo to EclipsNgirl
If you let the oil go low and you're hearing a "knocking" sound, you could be getting ready to spin a bearing too. I upgraded my turbo and the bolts kept coming loose and leaking out all the oil. Mine went too low and I started hearing this "knocking" sound around 3g and it ended up being a spun bearing. Hopefully this isn't it, but to me it sounds like a rod knocking.
98 Eclipse gst-race ready
95 Eclipse gst-stock
92 Eclipse GST-parts car
91 Talon tsi RWD
87 Conquest-our new baby
EclipsNgirl is offline   Reply With Quote
Old 11-03-2004, 04:02 PM   #10
rysin91crx
ok first off partizan if you read the first post it stated that i just baught the car, from some guy. Therefore i had to go buy a manual. But now i'm not that worried about it no more, because i just got through talking to a guy who would sell me a 4g63 (engine) for $300 with everything. Not bad... I think. So I would like to say thank you to everyone for your help.
Old 11-03-2004, 07:54 PM   #11
EclipsNgirl
You have a 1.8 engine and you're buying a 2.0 to put in it? It's not as easy to switch them as just taking one out and installing the other. You know that right?
91 Talon tsi RWD
Old 11-03-2004, 08:49 PM   #12
97_3clipse
97_3clipse's Avatar
Send a message via AIM to 97_3clipse
^^^word...^^^
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
97_3clipse is offline   Reply With Quote
Old 11-04-2004, 05:13 PM   #13
WankelTII
I like my 1.8, they are the closest thing to indestructable that there is! They are non interfierence motors, so if the timing belt goes its no biggie. I had one spin a balance shaft bearing at over 200,000 miles which sucked but there was almost no cylider wear and everything looked wonderful other than that one bearing. Im in the process of turbocharging mine right now, IMO thats alot easier than doin a swap. Of course it all takes work.
Old 11-04-2004, 05:15 PM   #14
WankelTII
If you do put that 2.0 in your car, you better change the timing belt first, i have seen them go in under 60,000 miles.
Old 11-04-2004, 09:07 PM   #15
1stGenRocks
hey wankel if you need any pats email me i have one that im parting out and all the engine is good with 156k except the bshaft bearing spun out
-1stGenRocks-
