Heater/AC help?
Ahh basically the heater and ac does not work and isnt even blowing any air.. any suggestions?
![]() Join Date: Sep 2004
Re: Heater/AC help?
It could be broken solider joints in the logicon or a bad relay on the blower motor assembly. Can you hear the ducts opening and closing when you change the option where you want the air to blow ei. defrost, floor, upper vents?
![]() Join Date: Aug 2004
I got the same problem man
#4 | ||
Re: Re: Heater/AC help?
No noise is made but when u slide the bar from hot to cold u hear a click from one side to the other |
Re: Heater/AC help?
Well it seems both sites that I have in my favorites aren't working now but here's the site if they work for you then it should give you a basic run down as to what the problem with the logicon is ....www.atlantarx7.com/secondgenfaqs.html
I'm not saying that this is your problem but it is something that can cause the problem you're describing. |
