91 C1500 Almost kills then fine
I've had this problem with my 91 c1500 4.3L (170,000m). After I start it, it idles fine and then when i shift it into reverse or drive, it almost kills..drops as though gas was shut off, it doesn't kill, but damn near. It seems to find or adjust it self very quickly and then everything is fine. No other idle issues..maybe a little rough every now an again but nothing noticeble.
Any ideas? New: temp sensor, fule pump (3yr), failsafer therm, caps, etc, just about everything else.. |
Re: 91 C1500 Almost kills then fine
Could be the idle air control valve is getting gummed up and needs cleaned or replaced.
NO 4 N JUNK ![]() 1994 GMC K1500 XC 5.7L 2008 Chevy Impala LTZ |
Has the battery been unhooked or changed before this started?
'99 Blazer LT Loaded, K&N Filter, Pioneer Super Tuner,Viper '98 Pontiac Grand Prix GT, 3.8 '88 K1500 Cheyenne, 5.0, stock, bought new '86 Nissan 720 Trash Truck '69 C/10 step side, 307, all original, second owner, in process of restore. The person who says it cannot be done should not interrurt the person doing it. Share your knowledge. It is a way to achieve immortality. Allen- Paintman Wrenchtwister Broompusher |
thanks for the feedback guys.
The IAC is about a year old..i could try to clean it. I have not cleaned it. The battery is constantly connected and reconnected due to working on other part of the truck etc. What is the connection between the battery being connnected and reconnected and a momentary idle slump. It does this slump thing every day on first start, not just the time after I connected the neg. lead. Please advise. thanks |
thanks for the input guys, but none of this has helped. Strange problem. Now that's it got up to 100 degrees again it's not as bad. When its been cold, it acts up again. It has to have something to do with the temperature, but like i said, i just put in a new sensor..
any other suggestions from anyone? thanks all. |
will i had a problem like this in my '91 350...like you i checked everything i could and nothing...then someone said to check the rotor...not the cap and just the little thing dat spins on top..but the rotor shaft...i pulled mine and oil a few spots dat looked like it needed it...and no more problem, runs good and no more stalling in the drive way....but i would suggest replacing it if it looks bad to you..
