Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 10-19-2004, 12:14 AM
solotop186 solotop186 is offline
b13 1.6 se brake upgrade
i want to upgrade my brakes on my 1.6 sentra se and was wondering if nx2000 brakes would fit and bolt up if i were to buy the rotor calipers pads and all
thanks
Old 10-19-2004, 12:40 PM
In2Deep In2Deep is offline
Re: b13 1.6 se brake upgrade
here's what you need...calipers, rotors, pads, all hardware, and caliper brackets (torque mounts). you will also need to get different wheels, as the 1.6 se wheels are too small for the nx brakes. nx wheels work and se-r wheels work with a little grinding of the top of the caliper. hope this helps.
1991 Ford Explorer 4d, 4wd, 5sp
1994 Nissan Sentra XE w/JDM sr20 swap - sold
Old 10-19-2004, 03:33 PM
i have a set of se-r wheel all i need to do is put new tires on them thanks
Old 11-03-2004, 01:53 AM
SR20B12's Avatar
SR20B12 SR20B12 is offline
if your not going to put the sr20 or turbo the nutz out of your ga10de or have 300+ hp.
Don't bother with the nx2000 conversion. just up grade to the (ad18ve SE-R) or (ad18vb kn13 pulsar) frt brakes you won't need the prop. valve just the booster from either car.if you want discs x4 you need everything from your donor car . note if your going from drum to disc you will need the kit from fast brakes. painless install.
Now the rear discs from the nx2000 are the same as the SE-R.
the only change the two car had is the nx has bigger vented frt.discs
and a bigger booster. that's it. and the fact you need 15 in wheels to
cover the massive frt. brakes. if you go Ad18 system it will do the same job but cheaper for you.
also check www.fastbrakes.com
they have a kit for b13's e- mail them if you have any queastions.
Chip-
B12 coupe w/SR20DE
91 AE92 Daily Grinder.
