Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 10-15-2004, 10:07 AM
ramaks ramaks is offline
Cool Engine Dies +Radiator Leaks
Hello all!!
I am a newbie and i recently bought an Altima GXE 93.It's got 137k miles on it.Frankly got it for $1200.Well it seemed to run good.
1.When you let the Engine Idle ,after some time it sputters ..keeps happening for some time..normal running..sputters..normal running and after 5/7 mins ultimately dies down.
2.The Radiator leaks.I might have to replace it.Is it possible for me to use some kind of leak fix.Could a leaking radiator damage other parts too in the car??
Thank you folks.I would appreciate your advice.
Ramaks
Old 10-15-2004, 12:33 PM
jmrev's Avatar
jmrev jmrev is offline
Re: Engine Dies +Radiator Leaks
it might have something to do with your radiator, i mean check it out becuase if its leaking then youll have to replace it. I dont think its anything else, your car is M.T or A.T?
Old 10-15-2004, 01:15 PM
Re: Re: Engine Dies +Radiator Leaks
Hey!!Thanks
Its got an automatic transmission.The engine problem...i believe it could be an engine misfire but then i am not so sure..
Old 10-28-2004, 10:41 AM
Hi Guys!!!
My mechanic fixed the car.Hope this will be helpful for others who face the same problem.
1.The problem was with one of the spark plugs.Also it seems that Bam- Bam was right ( for a qns in my other post).Somwhow more fuel than was really necessary was being injected and this was causing problems too..
Cheers
rks
