| Off-Topic Talk about anything other than cars. |
tire hop
got z rated tires is this why i get wheel hop cause of the grip? i just drove my friends stock eclipse and the tires spun instead of hopping. also mine are 19" rims. how much does that mess with my low end compared to stock 16" thanks guys
I dunno about the Z-rating affecting wheel hop, I thought that usually meant something about your suspension. As for 19's affecting your low end torque, yes, very much so. This is why most ppl reccomend not to get over 17" wheels. The onlt way you can get the same amount of low end torque out of 19's is to either A: Regear Transmission, B:Get alot of horsepower, or C: just get 17s (I use 225/45/17)
Re: tire hop
and sell me the 19's
-1997 Eclipse Spyder GST |Stock| -1990 Eclipse GSX |ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar| |
It does have some to do with the tires, but the tires didnt cause it, they just made you notice it. Yeah, i would drop down a couple sizes, but there is stuff that will help stop the hop!
stiffer engine and tranny mounts strut bar stiffer springs lowering the car I would look into some urethane engine mounts and a BETTER strut bar if you already have one, like one that doesnt have adjustable pieces or that bolts to the firewall too. If you dont already have one, try the $20 ebay one first, cant hurt. If you do change the wheels, the lighter the better! |
Re: tire hop
have done all of these to my 97 gs-t and i still get wheelhop with the stock 16's just my
![]() Bottles are for babies - Real men get blown!!! Car pics 97 eclipse rs - Sold 99 eclipse gs - Blown Motor 97 eclipse gs-t - For Sale 98-99 eclipse gs-x - ![]() - Looking for one
Re: tire hop
a strut bar should help a little, but the engine mounts should make the most difference, in DSMs i think most of the wheel hop comes from chassis twist and flex so an X brace for the bottom of the car would probably make a big difference too.
Re: tire hop
does an lsd make a huge difference also since your right tire spins faster than your left. i too have this problem but only when its hot outside or on certain pavements/roads. well if motor mounts will help, since my car is in the shop, should i get better mounts put on now and what kind and so forth?
Team Addiktion 155 down the 47 |
Re: Re: tire hop
here is also a lsd
Re: tire hop
thanks....yeah ive never put a new motor in and i never had wheel hop or spins on my other cars so i was clueless as to how to make that stop
Re: tire hop
urethane motor mount inserts and an LSD should cure the problem to a noticable degree. Search for a detailed explanation on what causes wheel-hop...and how dangerous it can be for your car... launch techniques also help ease hop. search search search!
Re: tire hop
hey shypder, what kind of rims are those, those look tight on your car.
Re: tire hop
thanks. 17" 5Zigen Copse in hypderblack.
Re: tire hop
is your car lowered shypder?
![]() 99 GST/evo 3 16g/3" Catback/Intake w/filter/UICP/1g BOV/Complete prothane motor mount inserts/Boost gauge/AF ratio gauge/MBC/NGK Plugs/HotWires/17" Sport edition fox 5 racing rims w/Fuzion tires One retarded ass site! Geeeeeeeee My Car [url=http://www.myspace.com/nobledsm[/URL] |
Re: tire hop
"When Z-speed rated tires were first introduced, they were thought to reflect the highest tire speed rating that would ever be required, in excess of 240 km/h or 149 mph. While Z-speed rated tires are capable of speeds in excess of 149 mph, how far above 149 mph was not identified. That ultimately caused the automotive industry to add W- and Y-speed ratings to identify the tires that meet the needs of new vehicles that have extremely high top-speed capabilities." http://www.tirerack.com/tires/tirete...eral/speed.jsp <--this is a good short article that explains the rating system.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
sorry im still learning what is a LSD? dont think they make the better mounts for 99 420a engines. about to search for what wheel hop can do to my car but if anyone wants to point some out that i might miss feel free thanks guys
