Go Back   Automotive Forums .com Car Chat > Chevrolet > Malibu
Old 11-06-2004, 05:21 PM   #1
BiGwiLLswiLLy
Send a message via AIM to BiGwiLLswiLLy
No start
Car is a 2001 and wont start gets fuel and spark, wont run unless u keep sprayin starting fluid in... possible map sensor? has new fuel pump and get good pressure
BiGwiLLswiLLy is offline   Reply With Quote
Old 11-06-2004, 08:01 PM   #2
goofy4467
Re: No start
does it start then stop after 1-2 seconds?
goofy4467 is offline   Reply With Quote
Old 11-06-2004, 08:02 PM   #3
goofy4467
Re: No start
does the fuel pump run and shut off when the key is turned on?
Old 11-07-2004, 01:33 PM   #4
BiGwiLLswiLLy
fuel pump is good.....n it wont run unless u spry ether in it n as loong as u do it runs...
Old 11-07-2004, 02:20 PM   #5
goofy4467
if you say the pump runs, then something is causing the computer to shut it off. Try this with the key on before start you should be able to go to the rh side on the end of the aft fuel manifold is a test point for fuel psi. if you depress this fuel will shoot out (be careful). if it doesnt there is no fuel to the eng. If there is check this after starting there should still be fuel psi(leave the key on after trying to start otherwise it resets). if there is no fuel the computer cut it off for other reasons.
let me know
Old 11-09-2004, 02:57 PM   #6
steveareno4301
Re: No start
I have a 2001 with 60k miles just started doing the same thing. I changed the fuel filter, and looked at the plugs. I am getting spark also, but do not smell gas. Ether almost starts it. I have read on here that they have a anti theft fuel disable. Could this be the problem? So obviously I am curious as to what you find out.
steveareno4301 is offline   Reply With Quote
Old 11-09-2004, 04:04 PM   #7
dwalmop
Re: No start
yes. Definately could be the anti-theft system. Actually, that's the first thing I thought of when i read the original post. Have it checked out.
dwalmop is offline   Reply With Quote
Old 11-09-2004, 04:59 PM   #8
steveareno4301
Re: No start
Does any one know if there is a reset for the anti theft system. In other words how can I get it running again?
Old 11-09-2004, 07:31 PM   #9
BiGwiLLswiLLy
yea it was the anti-theft ive done that before but for some reason i forgot...u have toleave the key in the on position forlike 10 min or somethin then try n start it i think it was...well car runs now
