Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 05-23-2003, 04:52 PM
a_batchelor a_batchelor is offline
Auto Headlight on/off control 98 Aurora
My relay switch on my auto headlight control went bad as a result of an electrical problem. Looking for awswers to what may be the cause before I go to the dealer.
Old 05-23-2003, 08:40 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Go to the dealer you will be better off! Electrical is nothing to play with could cost more money to fix if you aren't sure what to do.
Old 05-24-2003, 10:56 AM
omegaic's Avatar
omegaic omegaic is offline
I had the same problem when I bought my '98 Aurora. It was a flood in perfect condition, except the headlight control module. The DRL's worked, and the Perimiter Lighting feature worked, but the headlights just would not come on with either the stick or the twilight sentinel. The dealer quoted me $450 to have the module replaced, I took it to my mechanic and had it done for $300.
01111001011011110111010100100000011000010111001001 10010100100000011100110110110101100001011100100111 0100
Old 06-29-2003, 02:11 PM
duplicate882000 duplicate882000 is offline
Question Relay for head lights
What was your result?? My paking lights flicker in the garage when it is hot.. The relays are making noise when driving ( hot outside) once in a while.. Do I need head light swith relay assembly??
Old 07-01-2003, 03:04 AM
Aurora11602 Aurora11602 is offline
duplicate... where you live at... I have a 96 aurora as well and you seem like your into a little speed buyin the aurora... Im in sacramento cali so hit me up.
Old 07-24-2003, 03:27 PM
Northernlights Northernlights is offline
aurora headlight switch problem
I have the same problem with my '98 aurora. buzzing noise sometimes from the dashboard, yellow bulb in headlights going on and off long after parked, security indicator beeping when I open the door after parking, large local GM dealer says never heard of this problem before!!! ...also quickly diagnosed problem as needing headlamp switch replaced (costs about US$400 for the part alone!)
I'm having trouble believing this is a unique problem. Also, I called a number of wreckers, only to discover that of the half dozen Auroras sitting around in their yards, ALL THE HEADLIGHT SWITCHES HAVE ALREADY BEEN PULLED !!! Wrecker tells me can't be a coincidence, obviously there's a problem with this part.
ANyone had any luck getting GM to confess to the part being defective to begin with?
