Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 10-14-2004, 08:52 PM   #1
breakaway_sparky
Send a message via Yahoo to breakaway_sparky
2000 S10 Cigarette Lighter
I keep replacing fuses in the cigarette light. Everytime I replace a fuse and attempt to use the lighter it blows a fuse. Could the lighter itself be bad or another cause.
breakaway_sparky is offline   Reply With Quote
Old 10-14-2004, 08:55 PM   #2
breakaway_sparky
Re: 2000 S10 Cigarette Lighter
Does anyone has a solution to my problem blowing fuses in lighter
Old 10-14-2004, 10:05 PM   #3
Mikado14
The Lighter plug has probably gone out to lunch and it will need to be replaced or you will blow another fuse and then another etc.
If you have another car you can steal the lighter from, try that and see if it still blows fuses. If it doesn't, then you only need the lighter, usually they just quit. If it blows the fuse, then the first paragraph is your answer.
Good Luck!
Mikado14 is offline   Reply With Quote
