Old 10-05-2004, 03:53 PM
Jim Sherman Jim Sherman is offline
1990 Jeep 4.0 Run Problem
I have a 1990 jeep 4.0 It will start , but when the key is turned back to the "run" position, the engine dies. (immediately) I have changed out the ignition swithch but to no avail. Any ideas?
Tks, Jim
Old 10-06-2004, 11:33 AM
thatdutchguy thatdutchguy is offline
Re: 1990 Jeep 4.0 Run Problem
I'am having the same thing goin on w/my1990 cherokee right now. About a year ago it would start , go to high idel then die. 4day in the shop and $230. later it was a $30. crank position sensor. I try to replace it my self but it still dies after high idel and is flashing a code 42 ?
Old 10-08-2004, 12:21 PM
found problem. It was the oxygen relay to the oxy temp senson in the intake manifold. I swith wires on the air cond. clutch relay and the oxy relay and she worked fine. I replaced the oxy relay and swithched the wires back and all is fine now.
Hope this helps you. The relays are by the battery. there are four of them. Switch wires with a known good one. ie. AC clutch.
See ya, Jim
