Old 09-29-2004, 08:32 PM   #1
ramos29
Unhappy power window not working
Hello people, I have a 95 pathfinder and I'm having problems with my powerwindow in the rear-passanger seat. I tried replacing the switch and nothing... it wont work from my driver window selectors or on the one in the back.... anyone have an idea?????
ramos29 is offline   Reply With Quote
Old 09-29-2004, 11:09 PM   #2
cabroncofan
Re: power window not working
I had the same problem with my 95 Pathfinder. The right rear window would go down using the master control switch, but it wouldn't go back up by the master switch. I took the master control switch out and took it apart (carefully), then I used a piece of fine sandpaper on "ALL" the contacts. Once I put the switch back together and it works fine. I saved myself $135.00 from the dealer for a new master switch. While you have the switch apart, you may want to put some DiElectric grease on the connectors as well. Good luck, let me know if that works.
cabroncofan is offline   Reply With Quote
