Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 09-23-2004, 10:37 AM
Dropped2KNeon Dropped2KNeon is offline
Send a message via Yahoo to Dropped2KNeon
Question Need Help w/ Diagnostics Codes
My Dodge Neon 2000 stalled 3 times already . 2 times while driving. I checked the diagnosics by cycling the ignition on/off 3X's. I get 2 codes:
P 1684 and P 1389
Does anybody know what they mean? Any help would be appreciated. I really don't want to take it to the dealer just yet cause of some bad experiences with them.
Old 09-23-2004, 10:51 AM
Re: Need Help w/ Diagnostics Codes
Ok I found out in extremeneon.com that:
P1684 - Battery has been disconnected within the last 50 starts
Thats understandable.
But:
P1389 - No ASD Relay Output Voltage to PCM.
That I don't really understand. Anyone have any input on this please let me know.
Old 09-30-2004, 05:18 PM
_shay _shay is offline
Send a message via AIM to _shay
I'm not sure if the SRT-4 hard codes are different .. but here are the ones given for the SRT-4 just in case someone's looking for those:
P0016-CRANKSHAFT/CAMSHAFT TIMING MISALIGNMENT
P0031-O2 SENSOR 1/1 HEATER CIRCUIT LOW
P0037-O2 SENSOR 1/2 HEATER CIRCUIT LOW
P0032-O2 SENSOR 1/1 HEATER CIRCUIT HIGH
P0038-O2 SENSOR 1/2 HEATER CIRCUIT HIGH
P0033-SURGE VALVE SOLENOID CIRCUIT
P0068-MANIFOLD PRESSURE/THROTTLE POSITION CORRELATION
P0071-AMBIENT TEMP SENSOR PERFORMANCE
P0072-AMBIENT TEMP SENSOR LOW
P0073-AMBIENT TEMP SENSOR HIGH
P0107-MAP SENSOR LOW
P0108-MAP SENSOR HIGH
P0111-INTAKE AIR TEMPERATURE SENSOR PERFORMANCE
P0112-INTAKE AIR TEMPERATURE SENSOR LOW
P0113-INTAKE AIR TEMPERATURE SENSOR HIGH
P0116-ENGINE COOLANT TEMPERATURE PERFORMANCE
P0117-ENGINE COOLANT TEMPERATURE SENSOR LOW
P0118-ENGINE COOLANT TEMPERATURE SENSOR HIGH
P0122-THROTTLE POSITION SENSOR #1 LOW
P0123-THROTTLE POSITION SENSOR #1 HIGH
P0125-INSUFFICIENT COOLANT TEMP FOR CLOSED-LOOP FUEL CONTROL
P0128-THERMOSTAT RATIONALITY
P0129-BAROMETRIC PRESSURE OUT-OF-RANGE
P0131-O2 SENSOR 1/1 VOLTAGE LOW
P0137-O2 SENSOR 1/2 VOLTAGE LOW
P0132-O2 SENSOR 1/1 VOLTAGE HIGH
P0138-O2 SENSOR 1/2 VOLTAGE HIGH
P0133-O2 SENSOR 1/1 SLOW RESPONSE
P0139-O2 SENSOR 1/2 SLOW RESPONSE
P0135-O2 SENSOR 1/1 HEATER PERFORMANCE
P0141-O2 SENSOR 1/2 HEATER PERFORMANCE
P0171-FUEL SYSTEM 1/1 LEAN
P0172-FUEL SYSTEM 1/1 RICH
P0201-FUEL INJECTOR #1
P0202-FUEL INJECTOR #2
P0203-FUEL INJECTOR #3
P0204-FUEL INJECTOR #4
P0234-OVERBOOST PERFORMANCE
P1106-BARO SOLENOID PERFORMANCE
P1188 TIP SENSOR PERFORMANCE
P0243-WASTEGATE SOLENOID CIRCUIT
P0300-MULTIPLE CYLINDER MISFIRE
P0301-CYLINDER #1 MISFIRE
P0302-CYLINDER #2 MISFIRE
P0303-CYLINDER #3 MISFIRE
P0304-CYLINDER #4 MISFIRE
P0315-NO CRANK SENSOR LEARNED
P0325-KNOCK SENSOR #1 CIRCUIT
P0335-CRANKSHAFT POSITION SENSOR CIRCUIT
P0339-CRANKSHAFT POSITION SENSOR INTERMITTENT
P0340-CAMSHAFT POSITION SENSOR CIRCUIT
P0344-CAMSHAFT POSITION SENSOR INTERMITTENT
P0420-CATALYTIC 1/1 EFFICIENCY
P0440-GENERAL EVAP SYSTEM FAILURE
P0441-EVAP PURGE SYSTEM PERFORMANCE
P0442-EVAP SYSTEM MEDIUM LEAK
P0443-EVAP PURGE SOLENOID CIRCUIT
P0452-NVLD PRESSURE SWITCH SENSE CIRCUIT LOW
P0453-NVLD PRESSURE SWITCH SENSE CIRCUIT HIGH
P0455-EVAP SYSTEM LARGE LEAK
P0456-EVAP SYSTEM SMALL LEAK
P0461-FUEL LEVEL SENSOR #1 PERFORMANCE
P0462-FUEL LEVEL SENSOR #1 LOW
P0463-FUEL LEVEL SENSOR #1 HIGH
P0480-COOLING FAN 1 CONTROL CIRCUIT
P0481-COOLING FAN 2 CONTROL CIRCUIT (NON-TURBO)
P0481-COOLING FAN 2 CONTROL CIRCUIT (TURBO)
P0498-NVLD CANISTER VENT VALVE SOLENOID CIRCUIT LOW
P0499-NVLD CANISTER VENT VALVE SOLENOID CIRCUIT HIGH
P0501-VEHICLE SPEED SENSOR #1 PERFORMANCE (AUTO TRANS)
P0501-VEHICLE SPEED SENSOR #1 PERFORMANCE (MANUAL TRANS)
P0506-IDLE SPEED LOW PERFORMANCE
P0507-IDLE SPEED HIGH PERFORMANCE
P0519-IDLE SPEED PERFORMANCE
P0508-IAC VALVE SENSE CIRCUIT LOW
P0509-IAC VALVE SENSE CIRCUIT HIGH
P0513-INVALID SKIM KEY
P0516-BATTERY TEMPERATURE SENSOR LOW
P0517-BATTERY TEMPERATURE SENSOR HIGH
P0522-OIL PRESSURE SENSOR LOW
P0551-POWER STEERING SWITCH PERFORMANCE
P0562-BATTERY VOLTAGE LOW
P0563-BATTERY VOLTAGE HIGH
P0572-BRAKE SWITCH #1 CIRCUIT LOW
P0573-BRAKE SWITCH #1 CIRCUIT HIGH
P0581-SPEED CONTROL SWITCH #1 HIGH
P0582-SPEED CONTROL VACUUM SOLENOID CIRCUIT
P0586-SPEED CONTROL VENT SOLENOID CIRCUIT
P0594-SPEED CONTROL SERVO POWER CIRCUIT
P0600-SERIAL COMMUNICATION LINK
P0601-INTERNAL MEMORY CHECKSUM INVALID
P0622-GENERATOR FIELD CONTROL CIRCUIT
P0627-FUEL PUMP RELAY CIRCUIT
P0630-VIN NOT PROGRAMMED IN PCM
P0632-ODOMETER NOT PROGRAMMED IN PCM
P0633-SKIM KEY NOT PROGRAMMED IN PCM
P0645-A/C CLUTCH RELAY CIRCUIT
P0660-MANIFOLD TUNE VALVE SOLENOID CIRCUIT
P0685-ASD RELAY CONTROL CIRCUIT
P0688-ASD RELAY SENSE CIRCUIT LOW
P0700-TRANSMISSION CONTROL SYSTEM
P0833-CLUTCH RELEASED SWITCH CIRCUIT
P0850-PARK/NEUTRAL SWITCH PERFORMANCE
P1105-TIP SENSOR SOLENOID CIRCUIT
P1115-GENERAL TEMP SENSOR PERFORMANCE
P1189-TIP SENSOR CIRCUIT LOW
P1190-TIP SENSOR CIRCUIT HIGH
P1593-SPEED CONTROL SWITCH STUCK
P1602-PCM NOT PROGRAMMED
P1603-PCM INTERNAL DUAL-PORT RAM COMMUNICATION
P1604-PCM INTERNAL DUAL-PORT RAM READ/WRITE INTEGRITY FAILURE
P1607-PCM INTERNAL SHUTDOWN TIMER RATIONALITY
P1696-EEPROM MEMORY WRITE DENIED/INVALID
P1697-EMR (SRI) MILEAGE NOT STORED
P1854-TIP BARO OUT OF RANGE
P2074-MANIFOLD PRESSURE/THROTTLE POSITION CORRELATION
- HIGH FLOW/VACUUM LEAK
P2096-DOWN STREAM FUEL SYSTEM 1/2 LEAN
P2097-DOWN STREAM FUEL SYSTEM 1/2 RICH
P2302-IGNITION COIL #1 SECONDARY CIRCUIT-INSUFFICIENT
IONIZATION
P2305-IGNITION COIL #2 SECONDARY CIRCUIT-INSUFFICIENT
IONIZATION
P2503-CHARGING SYSTEM VOLTAGE LOW
U0101-NO TRANSMISSION BUS MESSAGE
U0155-NO CLUSTER BUS MESSAGE
U0168-NO SKIM BUS MESSAGES
U110C-NO FUEL LEVEL BUS MESSAGE
2004 Blue SRT-4
2001 Ford F-150 Lightning
1995 Ford F-150 Lightning
MNSRT4.COM
