Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 11-27-2003, 12:57 AM
emsinson emsinson is offline
VW Jetta headlight problem
My VW Jetta low beam lights are not working (bulbs are OK) only the high-beam (only when you depress the signal swich). Could it be a relay problem or a switch problem? The low-beam lights went out all of a sudden. Please advise.
Old 11-27-2003, 02:57 AM
HeirMuench HeirMuench is offline
Re: VW Jetta headlight problem
I would check your fuses
Old 02-03-2004, 05:18 PM
tasteppe tasteppe is offline
emsinson - I have the same trouble with my headlights that you described in your 11/03 note. How did you solve it?
Old 09-29-2004, 09:53 AM
Brad Barrett Brad Barrett is offline
Re: Re: VW Jetta headlight problem
With mine i have one high beam headlamp gone and the high beam indicator won't come on!! Can you please help!!! bulb and fuses are good!!
Old 09-29-2004, 04:50 PM
boschmann boschmann is offline
If you have left high beam, but not right or dash idicator it pretty much has to be fuse #18 or the white wire coming from it (pin 18A on the fuseblock).
