Old 09-20-2004, 01:06 PM
Bas Carwash's Avatar
Bas Carwash Bas Carwash is offline
Question Turbo question
This has been up for over a thousands times, I know, but my questions are a little different. I'm busy putting an R32 engine into a R33 400R. Pretty much like NISMO400R did. I'm having some problems connecting the intercooler to the turbo's. I understand how to connect a intercooler to a single turbo, but I don't get the way a twin turbo is connected. Is the pipe from the intercooler just split up or something?
Next to that question I would like to know how I can make hoses for connecting the air intake to the turbo. Like on this pic:
http://www.pow-r.co.uk/tokyo99/rb26.htm
I hope you guys can help. I've searched for about 2 hours now, and just couldn't find anything usefull.
Thanks in advance
Old 09-20-2004, 01:29 PM
freakray freakray is offline
AF Modelrater
Re: Turbo question
Not a Skyline, but a Nissan....
http://www.xspeed.com.au/ssport/35z33/
AF User Guidelines
Old 09-20-2004, 01:33 PM
008's Avatar
008 008 is offline
Re: Turbo question
The intercoolers on twins usually have dual inlets, unless two separate intercoolers are used. The core is split so that the inlet has two separate tanks and the outlet has one tank.
Example
http://www.oddbjornsmotor.no/spearco...r/image004.jpg
-Ron
Old 09-20-2004, 02:53 PM
Re: Turbo question
Alright I see. Thanks for that. Just like I thought. So how about the hoses? Any suggestions?
Old 09-20-2004, 03:32 PM
geofroley geofroley is offline
Send a message via AIM to geofroley
Re: Re: Turbo question
You mean the pipes that transfer the air from the turbo? Styrene tube will do. If you mean another kind of hose, Deatail Master makes a braided hose line that looks really nice.
Old 09-20-2004, 04:10 PM
86_SR5's Avatar
86_SR5 86_SR5 is offline
Re: Turbo question
Styrene rod/pipe works nicely if you dont bend it more than a few degrees. Get some tube/rod the same size as the turbo inlet and route/bend how you need and then paint and glue the filters on the ends.
RIP Indian Larry RIP
April 28th, 1949 - August 30th 2004
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 09-20-2004, 04:39 PM
Re: Turbo question
The pipes for transport and stuff are clear to me. This is what I'm talking about.
I've seen some people making these things for their models. I want that too
Old 09-20-2004, 04:51 PM
nis.k.a.'s Avatar
nis.k.a. nis.k.a. is offline
Re: Turbo question
Couplers is what he's talking about. Some people use heat-shrink tubing or something similar. I usually paint mine on and use BMF as the straps.
nightmaR3Z
Old 09-20-2004, 05:08 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Re: Turbo question
I take a length of Scotch tape (cellophane tape, not masking tape) and cut it to the right width and about 3/4 of an inch long, then I wrap it around the "joint" and paint it, and use BMF for the clamps and a piece of straight pin of the screw used to tighten them. I stole the technique from FOTW, in his intercooler how-to.
Old 09-20-2004, 08:09 PM
86_SR5's Avatar
I couldn't have said it better willimo. However, I use Scotch Painters Masking Tape for mine.
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
