Series Vs. Stereo
I have 2 4-ohms subs. When wired in Series the effecitve load is 8-ohms. My amp is rated at 1x 300W @ 4-ohms or 2 x 150W @ 2-ohms.
When wired in series, the effecitve wattage is 150W total(or 75W per sub) When wired in stereo, the effective wattage is 75W per speaker as well. So what are advantages/disadvantage of running in series vs. stereo? |
I've never heard of "wired in stereo" before; I've only heard of wired in series and wired in parallel..
What kind of sub do you have? brand/model? Is it a mono amp or stereo? If you are taking a stereo amp and making it mono you would be bridging it. |
Yes...I mean running the amp in stereo or mono.
i have 2 Eclipse 86100.4 (10" 4ohm, Continuous Power Handling: 175W Music Power Handling: 350W). Pushing them i have a 150.2 Orion Colbalt amp. |
Re: Series Vs. Stereo
The only issue I see is when you run the two in series, the ohms is 8 which will lower the output wattage of the amp and therefore lessen the amps effectiveness. On the other hand, the amp will run cooler at 8 ohms instead of 4 or 2. But.... ....ultimately, for a amp that runs 4 ohms in MONO, you should have went with two 8 ohm subs and ran them in parallel or two 2 ohm subs and run them in series. that would have achieved the 4 ohm load. Or any combination of subs that net you a 4 ohm load.
Brandon '96 G20 - modified |
