Go Back   Automotive Forums Car Chat > Ford > Windstar
Old 08-24-2004, 04:40 PM
pierce76 pierce76 is offline
ABS Question
Here we go again...I first had problems with my rough idle...code 305 which #5 Cylinder misfire...I changed the plug and wire and it runs much better but I need to change the manifold gaskets, seals etc because their is a slight leak.
Anyway, once the CEL disappeared now my ABS light is on. Checked everything and it appears to be fine. Is this a commin problem with the winstar/ (Never again...will I buy a ford)
Old 08-25-2004, 07:16 PM
PumpItUp PumpItUp is offline
Re: ABS Question
Quite commin if you peruse the ABS and break warning lights coming on.. in the forum Firstly, Check the level of the brake fluid and top up..If you have an older Windstar wouldn't hurt to have the brake fluid changed anyways..
