Old 05-21-2001, 11:50 PM   #1
Schludwiller
XTerra Guy
Schludwiller's Avatar
A few weeks ago something flew up and hit my ABS line above the rear diff.
The drivers side wire came out, and my ABS is not functioning now. The connector that the wire pulled out of seems like a one-time use kind of thing. As far as I can see there is no way to get the wire back in.
Any suggestions?
Schludwiller is offline   Reply With Quote
Old 05-22-2001, 10:29 AM   #2
Philosopher
Philosopher's Avatar
Yikes. Sorry, I have no idea ... I can go look at mine during lunch and try to give you some feedback ... ?
Philosopher is offline   Reply With Quote
Old 05-22-2001, 11:42 AM   #3
DVSNCYNIKL
R.I.P. DAD 3/25/11
DVSNCYNIKL's Avatar
Send a message via ICQ to DVSNCYNIKL Send a message via AIM to DVSNCYNIKL Send a message via Yahoo to DVSNCYNIKL
Aside from going to the dealership and having it replaced. If you wanna do it yourself, you can visit your local radio shack(if they have one around there) or local electronics store, and get this wiring repair kit that they have with grips, connectors and stuff like that. I know it's kinda hard to understand what I'm saying, if you know what I'm talking about, then, you can do that.
Hope that helps.
Why do banks charge you a "non-sufficient funds fee" on money they already know you don't have?
DVSNCYNIKL is offline   Reply With Quote
Old 05-22-2001, 12:04 PM   #4
Schludwiller
XTerra Guy
I don't want to go to the dealer as they'll charge me an arm and a leg.
All Courtesy Nissan had was the entire sensor.
Old 05-22-2001, 12:20 PM   #5
DVSNCYNIKL
R.I.P. DAD 3/25/11
DVSNCYNIKL's Avatar
Sorry to hear that. Well then, there's option 2 as I suggested.
Old 05-22-2001, 02:23 PM   #6
Synchro
Send a message via ICQ to Synchro Send a message via Yahoo to Synchro
look at the bright side, this will be a great oppurtuity to lengthen that ABS line in preperation for more rear wheel travel.
Synchro is offline   Reply With Quote
Old 05-22-2001, 03:40 PM   #7
Philosopher
Sorry Schlud, I just went and looked and mine are stuffed up there and tight. Thought I might be able to give you some piece of brilliance but NOPE.
Old 05-22-2001, 03:54 PM   #8
xterrabull
The only thing I can think of is to disconnect the connector, figure out which wire goes with which terminals, solder new wires to the terminals, cut off the current connector, and attach your own connector (male-female type) to the freshly soldered-on wires and the existing wires.
This may or may not be feasible depending on what you have to work with when you unplug that connector.
xterrabull is offline   Reply With Quote
Old 05-22-2001, 04:26 PM   #9
Schludwiller
XTerra Guy
Got some good info.
Jamie at Xterrastore.com just sent me this info:
Hi Schlud,
> This is Jamie from Marlboro Nissan. We do have a terminal repair kit but
> every terminal is different. We would have to look at it first hand and
> match them up!! Your local Nissan dealer will have the same kit, or they
> should!! The terminal should only cost a buck or two, but the labor might
> be about$40 or $50. Sorry I couldn't help further!
> Jamie
> Jamie Chapman
> Internet parts consultant
> Marlboro Nissan
> 740 Boston Post Road
> Marlboro, MA 01752
> (508)481-3232
> (800)689-6560
Old 05-22-2001, 08:44 PM   #10
ChuckH
ChuckH's Avatar
I can't believe you still haven't fixed that!
I like the Radio Shack idea. You could extend the lengths of the wires using butt connectors or by soldering and then put a whole new connector on there that could still snap together. otherwise, you could just connect everything together withlout a snap connection.
Or if the dealer has the repair kit then you're all set.
ChuckH
ChuckH is offline   Reply With Quote
