Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
Old 07-08-2004, 06:44 PM
veilsidercng's Avatar
veilsidercng veilsidercng is offline
Send a message via AIM to veilsidercng
Exhaust heat sheilds
Hey I just got my exhaust replaced (from cat back) and after I got the car back when I first start up the car, and when I run about 1,100 rpm theres this noise. It wasn't to bad at first but it got worse and it was really annoying so I got underneath it and I found out its the heat sheild (not around the car just around the pipe) I'm not sure why its there and not the rest of the pipe but o well theres 4 tack welds holding it on but only 1 is attached so you think I should take it off, like its not going to let heat to something its not suposed to (its not by the tank its in the midle of the car) and if so how you think i shuld take it off i dont have a dremel tool i was thinking i could just rip it off if i could. thx
Old 07-08-2004, 08:03 PM
civicgrl civicgrl is offline
Re: Exhaust heat sheilds
Actually, I have the same problem (if yours makes a clicking sound). I posted the same question and people were saying that it's just the metal (midpiping/cat heat shield) expanding from being heated. Nothing to be concerned about. I just installed a brand new exhaust system on my car. But, I think I'm going to have the bolts and flanges welded to make sure there is no leakage and then maybe the clicking noise will stop. I wouldnt take the heat shield completely off though because it can cause a fire.
BullShifter's Avatar
BullShifter BullShifter is offline
That's a very common problem. Couple choices 1 Rip it off, 2. Install a large hose clamp to hold it in place, 3. replace them.
Old 07-10-2004, 12:43 AM
hey guys thanks for the advice but i just ripped it off, it wasnt the cat heat sheild just sheild around the pipe for some reason and i took it off and drove around and it doesnt do it anymore but i think theres a leak somewhere cause its alot louder then usual but it dont sound bad so its fine with me
Old 07-10-2004, 05:34 AM
~ls/vtec~'s Avatar
~ls/vtec~ ~ls/vtec~ is offline
Send a message via MSN to ~ls/vtec~
i took the heat shield off my cat and everything is fine...well theres actually nothing inside the cat...
