Go Back   Automotive Forums .com Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 07-05-2004, 07:05 PM   #1
shadowg23
tranny on '94 slipping
My '94 maxima w/v6 the tranny is slipping. When I try to accelerate from
65 to say 80, the rpm's go way up but the car won't speed up accordingly. Also, when accelerating from a dead stop, the car won't take off as quickly as it use to.
My question is, could the crank position sensor somehow be responsible
for the slipping tranny? A friend of mine says it's possible, but i sure as hell don't know.
The car only has 95K miles and has always been serviced at the designated intervals. I no longer have a mechanic I can trust and i've been screwed before. It's my wifes car. I own a Jeep Wrangler which I perform all the work on myself. But the maxima is a different story and anything other than routine maintenence and it goes to the shop.
Any help is appreciated!
shadowg23 is offline   Reply With Quote
Old 07-05-2004, 10:06 PM   #2
i3o2Matt
i3o2Matt's Avatar
Send a message via AIM to i3o2Matt Send a message via Yahoo to i3o2Matt
Re: tranny on '94 slipping
is the tranny a 5 speed manual?? if it is, then ur clutch is goin quick...its the same exact thing that happened to mine (i've got an 89 SE 5 spd)...luckily i was on my way to work, which is a mechanic shop, and i just left it there...they installed a used tranny n new clutch (the tranny was startin to go too...i had no first gear and in reverse the whole car would shudder) but the car is fine now...if its an auto im not sure what it could be...unless you're like really low on tranny fluid...
i3o2Matt is offline   Reply With Quote
Old 07-06-2004, 11:10 AM   #3
shadowg23
it's an automatic
Old 07-07-2004, 07:33 PM   #4
i3o2Matt
i3o2Matt's Avatar
oh ok...is the fluid topped off?? that could be the reason for it...it could be a sensor but im not sure
Old 07-07-2004, 09:36 PM   #5
dustrman03
Guest
Posts: n/a
perhaps a tune up is needed
Old 07-12-2004, 05:23 PM   #6
maxima90gxe
Re: Re: tranny on '94 slipping
Hi,
has the tranny fluid been change before?
maxima90gxe is offline   Reply With Quote
Old 07-13-2004, 12:15 PM   #7
Knight4
Send a message via MSN to Knight4
I suggest posting the same question at www.maxima.org. There are some pretty knowledgeable guys that hang out over there, especially in the 3rd gen forum. The site seems to be down this morning, however...
Knight4 is offline   Reply With Quote
Old 07-14-2004, 12:14 PM   #8
stmary
Had the same problem with my '92 maxima auto. Hit the gas, gear would drop, rpms go high but the gear never catches. It was the solenoid pack for me ....about $500 to fix though!
Worked great for the next 15k miles but than it started slipping again...so it could have been a bigger problem. Needless to say, i traded in the max as soon as i noticed it slipping again.
stmary is offline   Reply With Quote
