Old 07-05-2004, 02:06 AM
Josterhout Josterhout is offline
always power to radio
Hello:
I have a 1999 Tahoe and I have a prob with the radio. There is always power to the radio even when the Ignition Switch is off. I thought maybe the ignition switch was bad, but no other accessories are on when the switch is off, just the radio.
Has anyone else had this prob? if so how did they fix it?
Thanks
Jeff
Old 07-05-2004, 08:45 PM
JD68 JD68 is offline
is this a stock radio or aftermarket? if its aftermarket then check you yellow memory wire and red acc/start wire to see its properly wired. if its stock ill check some info and diag it with you. if your handy with a multimeter you can check the seperate leads and also fuses to see where the power is coming to the radio from.
gl
jd
Old 07-05-2004, 09:28 PM
Re: always power to radio
My radio is stock.
This problem just started yesturday. Now today everything seems to be working fine. The radio now shuts off when the key is off.
I hate electrical gremlins!
Jeff
