Go Back   Automotive Forums Car Chat > Oldsmobile > Alero
Old 02-24-2004, 04:40 PM
mrsparky637 mrsparky637 is offline
Unhappy 2000 Alero DTC PO440
My daughter has this car and she had it scanned and this code came up. We looked it up and one of the things was a loose gas cap. She checked her gas cap and it was loose. I took the battery cable off for awhile to reset SERVICE ENGINE SOON Light, but it didn't do any good.
Is there another way to reset this light, so we can see if the loose gas cap was the problem. Thank You!
Old 03-01-2004, 01:04 PM
piley piley is offline
Re: 2000 Alero DTC PO440
You need an OBDII scan tool or code reader to reset the trouble code. Any garage. some parts stores or even oil change centers can do this for you (for a fee of course).
Old 06-18-2004, 03:17 PM
jmg0924 jmg0924 is offline
Lightbulb
Alot of auto parts places (I always go to the local Autozone) will reset your PCM codes at no charge (assuming the code does not represent a problem that is dangerous or that would put you or others at risk if ignored)
Old 06-18-2004, 10:51 PM
JTrujillo86 JTrujillo86 is offline
Yep. Autozone does that for free.
Jeremy
Old 07-02-2004, 12:46 PM
tofast4u2catch tofast4u2catch is offline
One other thing, check the seal around it. It is possible for the cap to be bad and not alowing the tank to pressurize which in turn will pop that light on.
2000 Alero 2.4-skips, jerks, dies, poor gas mileage summersdad Alero 8 03-08-2012 09:23 PM
2000 Alero stalls at highway speed skeeter123 Alero 12 04-05-2011 10:48 PM
2000 Alero V6 will not start. Please help. slavetothought Alero 1 10-28-2010 08:45 AM
2000 Alero 3.4 ABS light on, code c1265 skeeter123 Alero 8 01-26-2010 07:51 AM
2000 Olds Alero DTC P0302 how do i fix this? wjbourre Alero 2 02-28-2006 05:42 PM
