Old 06-30-2004, 05:10 AM
smokeymicpot smokeymicpot is offline
Send a message via AIM to smokeymicpot
looking for a header for my car need some info
i found one on ebay and its 90 plus 35 for shiping and its ceramic coated
and its a 4-2-1.
whats the dif between the real dc sport 4-2-1 and this one for like half the price?
Old 06-30-2004, 05:38 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
Re: looking for a header for my car need some info
the quality and more than likely the power gains wont be as much , but sod paying twice as much for a little bit better quality and performance, go for it
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 06-30-2004, 09:21 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
I've noticed the cheapos look the same but sometimes the O2 sensor bung is on the side of one exhaust tube in the manifold (like stock) but the high dollar ones like DC have it at the end of the two collector pipes right before the cat... I don't know what the diff is though
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 06-30-2004, 09:49 AM
91civicDXdude's Avatar
91civicDXdude 91civicDXdude is offline
Send a message via MSN to 91civicDXdude
the stock location is better. WE, as obd0 honda fanatics, have the disadvantage of a 1 wire o2 sensor. this means it does not contain its own heating element. for an o2 sensor to work correctly, it needs to be at operating temperature. placing the o2 sensor further away from the ports increases warm up time, decreases gas mileage, and in some cases, causes a check engine light.
things to look for when buying a header...
1. The Collector. IMO, one of the most important aspects of any header is the collector. make sure the collector is smooth, and not just chopped off pipes with a flange welded to the outside.
2. Runners. The diameter and length is very important. You dont want a header that is restrictive, it defeats the purpose. The length of the primaries determines the power band. If you notice, a lot of very high dollar headers ($800+) have very long, wide primaries. You dont watn your runners too short.
3. Bends. Make sure all bends are smooth and mandrel bent. Look for "choke" areas. these are bad.
4. Material. Generally a Stainless Steel header will be a bit stronger than a mild steel, but mild steel is usually cheaper and sometime comes with a ceramic coating feature (I prefer ceramic).
What makes you think you should be spoonfed?
http://4thgencivic0.tripod.com
Old 06-30-2004, 10:07 AM
icE_x's Avatar
icE_x icE_x is offline
Send a message via AIM to icE_x
hmmz..well which headers are available now that are affordable and that work well? I know theres a 4-1 (which i wouldn't recommend) and a 4-2-1 by DC and some other no-name brands. I've heard some good things about DC and the price isn't too bad so i'd go with em IMO.
1990 Civic EX 4-Door Sedan - D16A6 - 204k miles
:: working on mechanical and cosmetic restoration ::
Old 06-30-2004, 12:58 PM
soo all the stuff you said to look for i guess i can't do it with out getting it here and looking at it.
Old 06-30-2004, 12:59 PM
take a look at the pictures... look at the quality of the welds and the bends, you can tell a decent header froma shitty one.
I like 4-1 headers, but ground clearance is next to none and often times you have to notch the front crossmember on 88-91 cars.
4-2-1 2 piece is my second pick becuase its very easy to install and still provides some power gains.
