Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV
Old 07-05-2004, 08:42 PM
Crishpen's Avatar
Crishpen Crishpen is offline
Exclamation Dying in Neutral
My 98 Civic LX (about 72k miles) would sometimes rev so low to the point of dying. This would happen whenever I'm not applying any gas. The car would start ok and have a good idle (around 1000 rpm) but after some driving, the rpm's would go down whenever I put it in neutral or depress the clutch without pressing the gas; often to the point that the engine would almost die. The car runs normally on the freeway though. The check engine light went on this morning. Any ideas to what could be happening?
Old 07-05-2004, 10:00 PM
97CivicX's Avatar
97CivicX 97CivicX is offline
Send a message via AIM to 97CivicX
Re: Dying in Neutral
that is the EXACT same problem with mine witht eh same millage too, except i havent gotten cel yet
D16Y7/D16Y8 mini-me swap
turbo coming this summer
Old 07-05-2004, 10:04 PM
BrokenLimits BrokenLimits is offline
Send a message via AIM to BrokenLimits
There is a screw on the back of the throttle body that controls idle. I think if you screw it in it lowers the idle if you loosen it, it raises it. Pick up a helms manual and look up Idle Screw.
Brandon
Columbus, OH and Orlando, FL
2000 Civic Si with fully built LS VTEC
Old 07-07-2004, 01:23 AM
Crishpen's Avatar
I changed the spark plugs today and the engine still has the problem. I'm not an expert but I don't think I have to play with the idle screw because it idles fine when I start the engine. The idle goes down after a couple minutes after driving.
Old 07-08-2004, 02:30 PM
Crishpen's Avatar
It was the 02 sensor thing.
Old 07-11-2004, 03:06 AM
Plasmex Plasmex is offline
Send a message via AIM to Plasmex
yeah 02 sensor would explain the engine light coming on
97 red honda civic lx sedan b16a w/ Type R head,full headwork Port and polished, ported intake manifold, 310cc RC injectors, ITR cams, Skunk2 adjstable camegears, VAFCII, modified apexi ws II exhaust
