Go Back   Automotive Forums .com Car Chat > Nissan > Primera | G20 > Suspension
Suspension setups, shocks, springs, tires, handling.
Old 05-16-2001, 01:28 AM   #1
northwestrally
Just bought a '94 G20t, and I'm considering getting the adjustable KYB's.
Adjusting the fronts would obviously be a quick procedure, but aren't the rears hard to get at? I haven't looked long & hard at it yet, but do any of you have experience with these? Maybe I'd gotten used to my old Golf with its rear strut towers always in my face.
Many Thanks. - Don
northwestrally is offline   Reply With Quote
Old 05-16-2001, 01:51 AM   #2
JustinP10
JustinP10's Avatar
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
Acutally getting at the rears is pretty simple, you get kinda dirty on your back (if you don't have a towel or something on the ground) and your arm from the inside of the wheel and stuff. All I'd recommend is possibly a flashlight, depending on time of day, and location (shade, sun, garage, etc.) here is a picture of the adjustment knob and location. You can see this is the driver side rear. You can reach from behind the rear tire to access the adjuster knob.
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
JustinP10 is offline   Reply With Quote
Old 05-16-2001, 12:48 PM   #3
bump909
Registered User
bump909's Avatar
justin, you put down 141whp?? with just advanced timing, pulley, header, and intake? could you show us the dyno sheet? my friend's 200sx se-r put down 139whp and he has aebs header and s3 cams (doesn't have ecu yet).
i'm just really curious, considering i have many of the same mods as you do. i still need pulleys though.
bump909 is offline   Reply With Quote
Old 05-16-2001, 01:27 PM   #4
northwestrally
Thanks for the picture & comments. I' don't intend to readjust the rears everyday of my life, but it's nice to know it not too daunting a task.
Old 05-16-2001, 08:49 PM   #5
JustinP10
JustinP10's Avatar
[quote]Originally posted by bump909
[b]justin, you put down 141whp?? with just advanced timing, pulley, header, and intake? could you show us the dyno sheet?
Yeah, I have a final tonight (actually in a little while :-( After the final i'll hook up my scanner and scan that sucker in... I have an excel spreadsheet of all the numbers too, but i don't think i can post that here.. it's on the so-cal serca site on yahoo groups for anyone who wants to look at that file. I also have a lightened flywheel (good for a couple extra whp). But yeah, that's basically it. I still have exhaust, cams, and ecu to go, so i'm thinking 160+ isn't out of the question, depending on cams of course. I could always go with the C series cams and throw down a lot of power, but i'd have to throw down the $$$ too.
And to northwestrally :
I don't adjust mine that much, usually only when i go to the track, and then i adjust once i'm there.
Justin McClanahan
95 G20
Old 05-17-2001, 01:43 AM   #6
JustinP10
JustinP10's Avatar
I scanned in the dyno. I'm gonna post it to the engine section.
Justin McClanahan
95 G20
Old 05-17-2001, 01:53 PM   #7
bump909
Registered User
bump909's Avatar
great justin, thanks for posting the dyno sheet. i'm curious to see how my car would do.. we almost have identical mods. i do need pulleys however. here's my list..
- hotshot CAI
- '93 intake cam from an NX2000
- advance timing to 19 degrees
- hotshot gen 3 header
- apex'i dunk muffler
- jun ultra lightweight flywheel
- act clutch
- b&m short throw shifter
- apex'i rev/speed meter
- powerstop x-drilled rotors w/ axxis pads up front
- 17" oz superleggerra wheels
Old 05-24-2001, 05:29 PM   #8
Soleman20
Send a message via AIM to Soleman20
KYB AGX
I have a '94 G20t also. I just installed the KYB AGX struts. The front are really easy to adjust. As for the back, I have 17" wheels which allows me to stick my hand through the spokes to get at the adjustment knob. If you can't fit your wrist through your wheels then u might have to slide under the car from the back.
Soleman20 is offline   Reply With Quote
Old 05-24-2001, 10:09 PM   #9
poppy_morenito
poppy_morenito's Avatar
Send a message via AIM to poppy_morenito Send a message via Yahoo to poppy_morenito
Can you tell what springs you used and post pic with the 17's ?
How is the ride ?
poppy_morenito is offline   Reply With Quote
Old 05-28-2001, 09:28 PM   #10
Soleman20
KYB AXG
The combo of the KYB AGX struts , the HKS springs, and the 17" rims makes the ride is a little harsh. The front is pretty low, but the back was not lowered as much. I guess it compensates for loads in the back seat and the trunk. On the bright side the car handels like a 4 door Porsche. I will post a pic when I get one on the computer.
