Go Back   Automotive Forums .com Car Chat > Jeep > Cherokee
Old 06-19-2004, 12:31 AM   #1
GPN 05
Front End Problems
OK back with more questions....
My front end .... "Pops" and "Creaks" when I'm turing.... I have looked under the fron end... and it's coming from the drivers side... I'm thinking maybe A-arms... or stering guide bushings... don't know... Need help though.
Corey
GPN 05 is offline   Reply With Quote
Old 06-28-2004, 10:22 AM   #2
joseph676
Re: Front End Problems
I have the same problem. I'v changed everything on the frontend and still haven't solved the problem
Joe
joseph676 is offline   Reply With Quote
Old 06-29-2004, 07:01 AM   #3
gtmud
I'm not alone!! My 00 XJ did the same thing for ever till I replaced the track bar, and went through every damn bolt in the front-end tightening them up. If you use your Jeep for its intended purpose, than I would advise this be done periodically. Also check your upper and lower ball joints, uppers are greasable, lowers area sealed(at least on my 00), check for any slop. By the way, was your XJ in an acident lately, I ask only because mine started cracking and such after a 90's chrystler new yorker hit my DS FRT tire. Good luck.
gtmud is offline   Reply With Quote
Old 06-30-2004, 10:27 PM   #4
Blackjeep
My front end .... "Pops" and "Creaks" when I'm turing.... I have looked under the fron end... and it's coming from the drivers side... I'm thinking maybe **>>>A-arms<<<<**... or stering guide bushings... don't know... Need help though.
Corey
There aren't any A-arms on a 4WD Cherokee.
Check your u-joints in the front axles. When mine went out it sounded like the front end was grinding itself to pieces!! They were really bad. They make less spectacular noises if not worn quite that much.
Hope you find the answer!
Blackjeep is offline   Reply With Quote
