Old 06-27-2004, 02:57 PM   #1
chevysrule
pcv valve
my hanes book has too many types of cars in it so it doesn't have a good discription of where the pcv valve is on my 3.1 lumina. The parts store sold me one but it doesn.t fit where they normally do on the valve cover. So if someone could help me out with a pic or something it would be great... I think the last owner of my car took it out and just stuck a hose in it???? thnks
chevysrule is offline   Reply With Quote
Old 06-27-2004, 03:20 PM   #2
Bauer4665
Bauer4665's Avatar
Hey, your PCV Valve is in the upper right hand corner of your front valve cover. It has a black boot on it and it's very easy to pop out. They are pretty cheap to buy from a local automotive store. Make sure you get the correct one if you are planning to change it.
Bauer4665 is offline   Reply With Quote
Old 06-27-2004, 11:22 PM   #3
quaddriver
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
T code? the pcv valve is under the intake in the REAR valve cover and is quite the %$%#$%#$ to change
quaddriver is offline   Reply With Quote
Old 06-28-2004, 12:19 AM   #4
chevysrule
of course
ya that makes sense cause on the front valve cover has just a tube going into it that the pcv i had bought would not fit into... so how much @#%* is it to change it seeing that it is on the rear one??? thnks
Old 06-29-2004, 08:00 PM   #5
newfslumina
All i did to change mine was to let the 2 front motor mounts go on top and pull the motor ahead. when u pull it ahead just put the bolt through the hole in the motor mount..you can see and access it pretty good from there then...also a great time to change rear plugs if ya need too seem this is the easiest way to change plugs as well....hope this is of help to ya
newfslumina is offline   Reply With Quote
