Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 06-15-2004, 11:21 AM
thompsonb18b1 thompsonb18b1 is offline
Send a message via ICQ to thompsonb18b1 Send a message via MSN to thompsonb18b1
Exclamation b18b1 crx swap HELP!!!!
I just got a 1994 acura rs B18b1 DOHC non-vtec motor and 5 speed tranny and I want to replace my d16a6(factory) with it. I dont know much about the b18 can someone help me that has done this swap before, like give me a little bit of info about the tranny hook-up motor mount location changes anyhting and everything would help,.
and tell me if you need more info
thank
BJ THOMPSON
Old 06-15-2004, 11:55 AM
Beyond Imagination's Avatar
Beyond Imagination Beyond Imagination is offline
Re: b18b1 crx swap HEPL!!!!
best source of information is a helms manual. use a cable tranny. use the drivers side mount, the passenger side tranny mount, and the rear engine mount. buy yourself a mount kit from hcp or hasport.
88 Honda CRX Si - B16
90 Honda CRX Si - B20VTEC
Old 06-15-2004, 12:39 PM
drag1320neon's Avatar
drag1320neon drag1320neon is offline
Send a message via Yahoo to drag1320neon
you have to buy a mount kit, you should also get a new fuel setup, cuase your pump and regulators arent going to do it and change the ecu
you aint gotta like me, you just mad cause i tell it how it is, and you tell it how it might be
CHECK OUT MY CARS HERE!
drag1320neon and 209neon's babys < 209 neon finished!>
Old 06-15-2004, 01:24 PM
uhhh ... why wouldn't the stock fuel pump and regulator work on the b18b?
Old 06-15-2004, 02:13 PM
it will work, but the fuel put out isnt the same as an integra, which wont make it run to its full potential
Old 06-17-2004, 02:56 PM
gs_r95 gs_r95 is offline
you need a motor mount kit and cable tranny the full pump will work just fine with that motor and find a pr4 ecu from a da integra. ive never heard of having to change the fuel pump and i have done several swaps into crx's civics and integra's. the ecu wil take care of the fuel so no need for that. just out of curiousity what year is your car.
Old 06-21-2004, 07:47 AM
Its an 88 si, full mugen wide body kit, all in grey primer ....pritty
Old 06-21-2004, 03:22 PM
envydisqbanpapi envydisqbanpapi is offline
does any noe where to find the complete b18b1 engine for my 95 honda or if u have a better egnine in mind tell me and make sure its complete plzz!!!
