Old 05-10-2001, 08:14 AM   #1
gothamist
gothamist's Avatar
I've been looking into winches a bit, and I've got a question...who has managed to fit a Warn HS9500 into an ARB bullbar? I just found out that it actually has less of an electrical draw than the XD9000 does for the same load, and considering how weak our electrical system is (esp. the alternator), it might be worth the extra $$$ just for that (not to mention the faster line speed.)
Basically, if I can get some reassurance from people that it will indeed fit (it's ~2" longer than the XD9000, but otherwise the same size), that will probably be the winch I wind up with, unless I find a terrific deal on the XD9000 like Synchro did.
Thoughts anyone?
p.s. to see the specs I was talking about in terms of line speed and electrical draw, go here:
http://www.gowarn.com/specshs9500.htm
http://www.gowarn.com/specsxd9000.htm
gothamist
gothamist is offline   Reply With Quote
Old 05-10-2001, 10:27 AM   #2
ScottG
I remember seeing a post on the Unofficial Board where someone had installed the HS9500 in the ARB. I don't think the HS9500 is much more expensive than the XD9000. In fact, I think I have seen magazine adds for the HS9500i that were cheaper than the XD9000.
ScottG is offline   Reply With Quote
Old 05-10-2001, 01:25 PM   #3
xterrabull
I do! I do!
I think I do, anyways. I know it's a HS (high speed) but I wasn't sure if it was 9000 or 9500; but if there is no such thing as a HS9000, then it must be a HS9500 (I know, I know, the logic is simply astounding).
Anyways, it fit tight but fine. I don't remember any details but it's in there.
I'll double check tonight but I'm 99% sure it's a HS9500 I have packed in there.
xterrabull is offline   Reply With Quote
Old 05-10-2001, 01:43 PM   #4
Philosopher
Philosopher's Avatar
As far as size goes, the only difference between the XD9K and the HS9500 is the size of the motor - it is slightly bigger in the HS. As far as putting it in the bar, it should bolt right up. The HS might get hotter faster because it will have less room behind tha ARB than the XD.
Philosopher is offline   Reply With Quote
Old 05-14-2001, 04:17 PM   #5
Thanatoz
Send a message via ICQ to Thanatoz
Warn info
Thanks for the heads up on that electrical info. You just made up my mind on which winch I'm getting. I was trying to figure out if the HS and the extra 500 lbs was worth the money. Here is a site that had their prices posted. Anybody know another place cheaper?
Warn Winch Prices Here
Thanatoz
Jee·ple (Jëp´pêl), n., -ples. 1. any of several ruminant mammals, esp. of genus Ignoramus, which purchase and drive Jeeps. see also sheeple.
Thanatoz is offline   Reply With Quote
Old 05-14-2001, 05:43 PM   #6
Mobycat
Mobycat's Avatar
Send a message via AIM to Mobycat
Even better prices...
Mobycat
MAXC
http://www.xterra-trail.net
Mobycat is offline   Reply With Quote
Old 05-15-2001, 12:09 PM   #7
Philosopher
Re: Even better prices...
Originally posted by Mobycat
www.discount4wd.com
Decent winch prices but they want $75 a piece for RS9000's! Yikes.
